Old 08-26-2015, 09:47 PM   #1
Jrainman
Jrainman's Avatar
Rocker question
Another new guy here with my first question, I have a 69 that I am restoring , ok so the PO started the restore about a year ago, he did the rocker inner and outer panels , and cab corners , But let just say that his installation was less then desirable .
So I am in the process of redoing all his work
I ordered new full outer rockers and new cab corners ,I made the mistake of not ordering Inners ,thinking I can deal with the PO inner rocker work , NOT So
So my question is can someone tell me the correct dimension s of the Inner Rocker panel ........... also gauge of metal
Jrainman is offline   Reply With Quote
Old 08-26-2015, 10:56 PM   #2
swamp rat
swamp rat's Avatar
Re: Rocker question
Much easyer to buy what you need..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-26-2015, 11:28 PM   #3
69chevytrucker
69chevytrucker's Avatar
Re: Rocker question
and cheaper i spent like $40 in metal and 4 hours trying to make inners and when i was mad enough i check to see how much new ones were i got new ones for like $12 a piece lesson learned lol
69chevytrucker is offline   Reply With Quote
Old 08-27-2015, 12:07 AM   #4
Jrainman
Jrainman's Avatar
Re: Rocker question
Thanks for the reply , I agree they are cheep and I would order them , but time is the issue , rockers and cab corners are here , I have correct 4' x 4' sheet of 18 ga auto panel grade sheet metal a 4' finger brake ,4' jump sheer . I am a sheet metal worker by trade so really no big deal for me to make .even if its a rolled piece , I have the equipment , Just looking for dimension .
Old 08-27-2015, 12:39 AM   #5
ekgguy
ekgguy's Avatar
Re: Rocker question
I just got my inner rockers from TABCO and them measure 40" long x 6" high. 3 5/8 then a 90 degree bend, 1 1/4 then another 90 degree bend the opposite way leaving 1 1/8. I had to trim some of the edge by the cab corner, but I opted for the longer length so I could trim if needed.
Hope this helps
https://tabcoparts.com/1234-41798.html
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline   Reply With Quote
Old 08-27-2015, 07:39 AM   #6
Jrainman
Jrainman's Avatar
Re: Rocker question
Hope this helps
Perfect thank you for taking the time to measure , I also ordered from Tabco ,took 5 days to get my corners . quality seem to be good and I here there corners fit good with out to much work to get them fitted in.
