At my wits end, motor getting hot. Input please
Hello everyone.
I haven't been much of a regular poster as of late. Life changes and all. Life changed for me again as of late. After nearly 17 years of employment, I was layed off. Business closing down. Well my cocern is that I will likely have to commute to work as well the job search. My truck is my daily driver. I have been pretty forunate in that I haven't had but 2 or so breakdowns in the last 3 years. And unforunately I was involved in an accident a little of a year ago, so the old girl is banged up. Ok, so my issue is that my motor gets really hot. Granted I live in Texas and it does get hot here, but I'm not too comfortable driving around with the motor @ 210 degrees. This is not a new issue however, it is not likely that I will live just down the road from work. Specs: 350 sbc. Stock, and way too many miles on the rebuild 18 years ago. 3 speed manual No A/C HEI distrubator ceramic coated headers 4 barrel Edelbrock carburator #1405, aluminum Edelbrock intake stock heads New 3 row Champion radiator Stock mechanical fan with heavy duty radiator shroud. I've been researching "overheating" threads posted on the forum and have found some good info. Now heating a wall though Motor has recently gone up to 210 degrees before I pulled over to cool things down. New sparkplug wires and sparkplugs, gapped @ .045 Cleaned out and rebuilt carburator. Drivers-side air-fuel mixture circuit was plugged up. Since cleared out. I feel that I have "enriched" the mixture thinking I might have been too lean previously. Initial timing is 13 degrees BTDC. Vaccum advance is new and is in working condition. # AR10. Stock springs and weights in distributor oiled up and freely moving. Recently replaced 3 inches fan spacer with a 1.5 inch spacer as I felt fan was too far in the shround. Replaced thermostat with new 180 degree unit. Just for grins boiled the old one, which was a 180 degree unit and it didn't open up until 215 degrees. I feel that the waterpump is working correctly as it does "pressurize" the radiator hoses. Any ideas? Something I may be missing? |
