Old 09-02-2015, 10:18 AM   #1
bevos68bowtie
Rear end bad
Anyone know if a 81 Camaro rear end will fit in my 68 c10
bevos68bowtie is offline   Reply With Quote
Old 09-02-2015, 12:06 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Rear end bad
are you switching to 5 on 4.75 lug pattern?
1967custom
michael bustamante is offline   Reply With Quote
Old 09-02-2015, 12:15 PM   #3
bevos68bowtie
Not sure about the bolt pattern but the rear end in it now came out of a 78 Chevy truck and it is 5 lug
Old 09-02-2015, 12:41 PM   #4
cooperhw
cooperhw's Avatar
Re: Rear end bad
78 truck bolt pattern is 5 on 5" pattern, car pattern (as previously mentioned) is 5 on 4.75". Wheels will not work. Probably easier to dig up another $150 rearend for the 73-87 truck.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 09-02-2015, 02:39 PM   #5
bevos68bowtie
The only reason I was looking at the Camaro rear end is it had pos track and 373 gears. Could I use the third member in the Camaro or put my axles in the Camaro rear end?
Old 09-02-2015, 03:15 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rear end bad
You can make any rear end fit in these trucks.
If the "3rd member" is out of a 10-bolt... then no.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-02-2015, 03:32 PM   #7
Bigdav160
Bigdav160's Avatar
Re: Rear end bad
If you have a Camaro 12 bolt posi it's worth more to the Camaro guy. You could sell it and buy a new posi/gear/bearings for your truck
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-02-2015, 05:31 PM   #8
Xeen
Xeen's Avatar
Re: Rear end bad
Check on craigslist for chevy truck parts and look for a guy with more than one ad because that is usually the guy with the small chevy truck parts yard.
You shouldn't have any trouble finding a 71-72 5-lug rear axle, and even less trouble finding a 67-70 rear axle.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-02-2015, 08:59 PM   #9
leftybass209
leftybass209's Avatar
Re: Rear end bad
It sounds like you're looking for a bolt in, in that respect; no, nothing except for a rear end from a 67-72 will fit if it's coil sprung. Even then, coil and leaf rear ends are different and won't just bolt in the opposite vehicle without slight mods.
The rear ends are also different widths between years. That isn't much of a concern unless you're running large tires or an odd backspacing.
leftybass209 is offline   Reply With Quote
