Old 08-31-2015, 02:01 PM   #1
WarMonger
WarMonger's Avatar
to gasket or not to gasket, that is the question
I have heard some people run gaskets and others don't? I was thinking of using gaskets. I cleaned and decked both surfaces. What do you guys think/recommend or have heard of?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 08-31-2015, 02:15 PM   #2
Taibo
Re: to gasket or not to gasket, that is the question
I would run a gasket with those. You still have low spots on the center ports but a gasket will make up that difference easier than continuing on with decking that header. Soft copper works really well on Iron manifolds bolted to iron heads. 32 Ounce (.050) sheet is available on the net in 12 x 12 pieces. Cut six rectangles slightly larger than each port, scribe and drill the holes and bolt them to the port. Use a ball peen hammer to tap around the edges of the perimeter and the center. The sharp harder edge of the manifold will cut the pieces out perfectly.
Now comes the part your wife is really going to love. Set your oven to 350 degrees, get a baking dish and put 1/2 inch of sand in the bottom. Put the copper gaskets on top, cover them with another 1/2 inch of sand and bake them for two hours. Turn the oven off and let it cool back to room temperature before opening the door. Your gaskets are now annealed and will be very soft. Soft enough to compress when the manifold is torqued down. Just remember, if you ever need to loosen those bolts, you will need a new set of gaskets.
Taibo is offline   Reply With Quote
Old 08-31-2015, 02:17 PM   #3
Fldawg
Fldawg's Avatar
i've always used gaskets, some of the new gaskets really do a good job, i've never heard of not using gaskets, and i've been a mechanic for over 27 years now
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 08-31-2015, 02:19 PM   #4
jocko
jocko's Avatar
Yes. I run the perforated metal type.
Old 08-31-2015, 02:20 PM   #5
picklito
I always use a gasket. And I like the metal-sandwich version on both headers and cast manifolds. Gaskets dry, anti-seize on the bolts.
picklito is offline   Reply With Quote
Old 08-31-2015, 02:43 PM   #6
WarMonger
WarMonger's Avatar
This pic shows the low spot, but I have everything flush now. Thanks for all the advice. I'm gonna go with gaskets. I spent all weekend sanding surfaces down. I even made a phonelic plate for the carb
1970 C20
-_--_--_- ______
1972 K5
Old 08-31-2015, 03:49 PM   #7
Bigdav160
Bigdav160's Avatar
GM quit using gaskets there in the early 1980's
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-31-2015, 03:58 PM   #8
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I run the manifolds with no gaskets and no leaks.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 08-31-2015, 04:01 PM   #9
Taibo
Sanderson uses a 1/8 in wide by 1/16 in high sealing ring machined into the aluminum header flange on their headers. No gaskets. If you use locking fasteners, or just keep the bolts properly torqued they will never leak.
Old 08-31-2015, 04:56 PM   #10
leftybass209
leftybass209's Avatar
No gaskets from the factory. If they were decked correctly, and verified flat with a level, they'll be fine without gaskets. I have a good number of miles on mine, leak free. Best of luck with your decision.
leftybass209 is offline   Reply With Quote
Old 08-31-2015, 06:28 PM   #11
hamjet
hamjet's Avatar
Where did you get the phonelic material to make your own?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 08-31-2015, 09:56 PM   #12
indymachinist
Absolutely use gaskets.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 08-31-2015, 10:18 PM   #13
GRX
GRX's Avatar
Unless you have two flat surfaces, which you don't from looking at the first image. Use gaskets.
GRX is offline   Reply With Quote
Old 09-01-2015, 09:54 AM   #14
WarMonger
WarMonger's Avatar
Lets just say it fell off a truck about 7 years ago.
1970 C20
-_--_--_- ______
1972 K5
Old 09-01-2015, 09:55 AM   #15
WarMonger
WarMonger's Avatar
I do have 2 perfectly decked surfaces. the pic is just in the middle of the process. That's why I'm asking if to use gaskets or not.
1970 C20
-_--_--_- ______
1972 K5
Old 09-01-2015, 10:21 AM   #16
Aruba1
How did you deck the surfaces? Use gasket, I have never removed a manifold that did not have a gasket.
Aruba1 is offline   Reply With Quote
Old 09-01-2015, 10:23 AM   #17
geezer#99
geezer#99's Avatar
If you're trying to keep heat away from your carb, you need a heat shield instead of a spacer.
Especially with a holley.
https://www.holley.com/products/fuel...s/parts/108-70
Old 09-01-2015, 10:28 AM   #18
GRX
GRX's Avatar
So all the surfaces were checked and confirmed flat (with each other) with a good straight edge?
Old 09-01-2015, 10:29 AM   #19
WarMonger
WarMonger's Avatar
A phenolic plate is an absolute heat shield.
1970 C20
-_--_--_- ______
1972 K5
Old 09-01-2015, 10:31 AM   #20
WarMonger
WarMonger's Avatar
Yup, I have a machined straight edge and a machined 2 foot sanding bar. all surfaces are flat with each other. Took me 4 hours to do the block and headers. It was not fun.
1970 C20
-_--_--_- ______
1972 K5
Old 09-01-2015, 10:36 AM   #21
GRX
GRX's Avatar
Cool deal. Was just asking since I have seen a lot of sbc heads blown out at the gasket surfaces from them just being sanded smooth with a disk.
Old 09-01-2015, 11:00 AM   #22
geezer#99
geezer#99's Avatar
Yup!!
For a carb that has the fuel bowls directly above the plenum.
A holley needs a shield under the bowls.
Old 09-01-2015, 11:13 AM   #23
Keith Seymore
Keith Seymore's Avatar
A phenolic plate is an absolute heat barrier.
...for a structure borne heat transmssion path.
You also need the shield for convection (air borne heat path).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-01-2015, 12:42 PM   #24
cleszkie
cleszkie's Avatar
I respect the effort that went into "decking" the heads and manifolds. However, dropping in a good set of soft aluminum gaskets would give you the same result without all the elbow grease. I did that many years ago and never looked back. The aluminum gaskets are also reusable if you have to pull a manifold. BTW, have you fired the engine without gaskets to check the decking job? That should answer your question.
cleszkie is offline   Reply With Quote
Old 09-01-2015, 01:45 PM   #25
Taibo
Isn't it amazing how lots of useful stuff seems to fall off trucks.....
