Las Vegas frame swap regulations
I am looking to swap my c20 frame out for a c10 short frame.
anybody know the rules or regulations they have for that. im being told a bunch of differant things.
1997 GMC SIERRA STEPSIDE 1986 CHEVY C10 1968 CHEVY C20 -JOSH IG:bopper702 |
Re: Las Vegas frame swap regulations
Your local State Troopers or DMV will have the answers.
Not so difficult. the vin is on the cab and on the driver side front top of the frame just a bit back from the steering box.
simply put/bolt your cab on that frame. few if any will look further thn the vin onthe cab if your paperwork is all in order. |
take the safe way. talk to the state people. better safe than sorry. i'm in the same boat here in florida but with the cab
#5 | |
Yes the best proper legal way is to go through DMV but ,,,,,,,,,,,,,,,,,,,,,,, Sometimes it's easier to get forgiveness than permission. Usually they check the cab vin and want to see those numbers in one more location. The glove box SPID works in AZ. Usually every state is different though. Soooooooo, Let your conscience be your guide.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Thanks guys. Ima stop by the dmv on monday see what they say. I though id ask on here maybe someone who already went through this would explain the process they went through.
Posted via Mobile Device |
![]() Join Date: Jul 2010
My truck was titled in AZ when I purchased it. The first thing I did was trailer it to NV DMV for inspection so I could get a NV title in my name and, yes they did inspect my frame for the stamped vin number. I would definitely check with the DMV. Monday is going to be crazy since DMV was closed both Fri&Sat because of the 4th. Good luck.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
Not only knowing what's correct can avert problems, but the DMV can be the source for solutions, so one can comply with the law. I've lived in several different states, and DC, and the requirements vary in each of them. Sometimes a state DMV website has FAQ's that help, or a contact for clarification of questions not addressed by the FAQ.
#9 | |
they always inspect vins on all out of state vehicles. but I will stop by this morn and double check. thanks
What a pain in the ass.. so I went to the dmv and I got all the info and paperwork I needed on how to go about getting it done. But they say even then it can be an "2015" assembled vehicle. You kidding me. As if I were building a kit car!! Frustrating.
![]() Join Date: Sep 2010
I would grind off the VIN off the frame, get some number/ letter stamps and stamp your VIN into the frame.
Location: Formerly MD and San Diego, now loving life in Arizona
If you own a clear title to both the frame you want to use and the body you have, the process should be fairly easy. Do not ignore your state laws because it is too inconvenient. Many people have gotten in trouble for doing things incorrectly.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
#14 | |
https://www.youtube.com/watch?v=9pdp...eature=youtube |
#15 | |
#16 |
Well guys , went over to tuckers classic auto parts out here in Las Vegas and I found a bit cheaper route and less complicated. I guess I'm going to be cutting my frame. Tuckers is going to be helping me out with the frame. Thanks for the help.
#17 |
Tom over at Tucker's does great work. Sounds like a good choice . He will do it right.
#18 |
![]() Join Date: Nov 2013
I would think downgrading from 3/4 to 1/2 ton frame is a big issue-legally speaking
#19 |
Collector of Projects
Hey Josh, did you ever get this sorted out? Did Tuckers handle the frame modifications for you?
