Old 09-06-2017, 08:25 PM   #1
luvbowties
luvbowties's Avatar
Question Side glasses go only halfway down.
Had new insulation, channel bars & fuzzies put in doors of '66 during rebuild. Got it back in winter, so did not roll down windows until warm weather. That's when I realized BOTH glasses "bottomed out" when they got about half way down. Builder told me regulators were worn out; so I bought just one for pass. side to ensure he was right. He replaced that one, but it is no better after new reg.
Anyone else run into this problem? Any suggestions/ideas?
S
luvbowties is offline   Reply With Quote
Old 09-06-2017, 08:35 PM   #2
65truckowner
65truckowner's Avatar
Re: Side glasses go only halfway down.
Sounds like the regulator is not installed right. Pull the door panel and check it out should be an easy fix
65truckowner is offline   Reply With Quote
Old 09-07-2017, 01:06 AM   #3
kerber63
kerber63's Avatar
Your regulator wheels might be hitting the screws that hold the regulator channel to the door glass mounting frame. Pull your door panel and check where the wheels stop when the window bottoms out.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 09-07-2017, 10:54 PM   #4
rvrfoot
Take off the door panel and look inside and see whats happing.
rvrfoot is offline   Reply With Quote
