2010 escalade seat swap into 72 K20
So I got really lucky and picked up a set of front bucket seats from a 2010 cadillac escalade they are black leather heated, cooled, power and lumbar. These seats are going into my 72 K20
![]() My problem is with the drivers seat controls, I have traced the wires which make the movement controls and lumbar work (small red & white, small purple & white and large red & white plus large black ground), however they work intermitantly. Anyone know if there is another wire I also need to connect out of the 20-25 wires in plug which would normally plug into the harness of the escalade? The passenger seat had less wiring an took a few minutes to get it working but this drivers seat. I'll get some pics up tomorrow, the seats are back on the ground right now and i've lost patience with this intermitant control for today. |
Re: 2010 escalade seat swap into 72 K20
I can't help you with your wires but I would really like to see some pics of this soon as your done, or even in the process. These are my seats of choice if I end up switching from stock.
1970 GMC |
Silverado seats
As promised here are some pics of the seats bare in mind this is ground up build so the truck is not yet complete.
72 K20 ![]() |
Man, those Silverado seats are sweet. What year?
USCG "Support Search & Rescue, Get Lost" |
Yeah I like them with no head rest and a console too
72bbck were you able to get these operational. I have a similar set, thanks
I got the seats to work but only intermit. Seems like there is a position sensor for each function and since its not hooked up the motors just stop hence the intermittence. I am however speculating.
72 K20 ![]() |
those silverado look great. What year did you get them out of?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
Old member
I used the 99 Tahoe seats with no memory. 6 way electric and heated. All works well now. I recovered them myself after putting the E-bay heaters in.
The memory settings are what has the seats not functioning correct is what I would think. After looking back on this I see where I posted on this before in your other thread. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=645808
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Old member
This may help you with the seats!
The guy posted pictures also. ![]() http://www.gmtruckclub.com/forum/thr...9-2006.108685/
Correct me if I'm wrong, but the 99 Tahoe Seats your referring to are the black ones that are pictured correct? I'd like to get a confirmation of the year/make/model of the red seats that 67ctener posted.
All about them K’s
![]() Join Date: Jun 2014
Those look to me to be 07+ Silverado seats and console that have the backs/headrests trimmed.im positive they've been re-upolstered as well
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
![]() Join Date: Nov 2007
Nice seats 72BBCK20 ! Are you certain they were functioning normally before you got a hold of them ? If so I would suspect a loose connection somewhere in your wiring. A wiring diagram would really help out to identify the wires/ functions to the Power Seat Module/ECU & motors
72 C20 Longbed 05 1500 Z71 |
#15 |
Old member
These are 99 Tahoe Electric/heated seats in mine.
They have been recovered to. Before ![]() After
#16 |
I'm guessing pure speculation that 67 centers seats are 2008+ model that he had re covered eliminated headrests etc. possibly even chopped them a little.
Tags |
escalade seat swap |
