Old 10-07-2015, 09:04 AM   #1
SoCoC10
SoCoC10's Avatar
Help Id rear differential Eaton HO52 or?
Like the title says I just want to confirm the rear differential out of my 67 C20 is a Eaton HO52? I had no problems with it just swapped to 5 on 5" rear diff to complete my C20 long bed to C10 Short bed conversion. New diff has a little more freeway friendly 3.73 ratio vs old diffs 4.10.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 10-07-2015, 11:10 AM   #2
kwmech
Re: Help Id rear differential Eaton HO52 or?
Looks like one to me, how many bolts holding the 3rd member in and the rear cover?
Old 10-07-2015, 11:12 AM   #3
Sklptrljay
Sklptrljay's Avatar
Looks like it to me.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 10-07-2015, 11:31 PM   #4
It's not a Dana 60 so it's a corporate HO52
Old 10-07-2015, 11:36 PM   #5
BCOWANWHEELS
c-20 is ho52,c-30 is ho72 . both models are extreamly obsoliete
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-08-2015, 01:27 AM   #6
Motorfist
Well you're half right. I wouldn't say they are extremely obsolete. I'm doing gaskets and seals in my sons ho72 this week. Napa had everything in stock. They can be modified with 14 bolt brakes if desired and are generally tough as hell.
67 c30 Cab and Chassis (ex motorhome truck)
68 c10 LWB
70 c30 Cab and Chassis 133" converted to Longhorn
72 K10 LWB Rust Bucket Hunting Truck
Motorfist is offline   Reply With Quote
Old 10-08-2015, 01:42 AM   #7
BCOWANWHEELS
I,am talkiin internals,
Old 10-08-2015, 01:51 AM   #8
Motorfist
Copy that and agree on internals.
68 c10 LWB
Old 10-08-2015, 07:10 AM   #9
They'll be extremely obsolete once no more good used parts are available... if it ever needs any. As it is now, the driveshaft turns the pinion, the pinion turns the ring gear, the ring gear turns the axle shafts, and the wheels roll on down the road just the same as a brand new truck or the one that comes out next year.
Old 10-08-2015, 02:30 PM   #10
BCOWANWHEELS
I,d clean out the diff real well and install syn lube. it will help it live aloot longer.
Old 10-08-2015, 05:56 PM   #11
mike16
its an HO 52. certainly NOT obsolete. parts support for the generic stuf is still available, the rest NOS through ebay or used... just about anywere. A good rear end. Do a search here or better yet over in the driveleline section to learn more and interesting things about this near bullet proof rear. And also lots of info onother 4x4 specific forums.
mike16 is offline   Reply With Quote
Old 10-15-2015, 11:02 PM   #12
SoCoC10
SoCoC10's Avatar
Thanks for the help guys. I posted an ad for it in the parts for sale area if one of you or someone you know is looking for one.
Old 10-16-2015, 08:20 AM   #13
midniteblues
midniteblues's Avatar
I have been lookin at a 71 9ft stepper 1ton. I thought the rear in this truck is a ho52. Am I wrong? it's all oe would it be ho72?
Op sorry for the jack
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 10-16-2015, 02:04 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup -- an original Eaton in a 1-ton will be an HO72.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-20-2015, 06:49 PM   #15
Motorfist
Correct and here is a handy tech article with part numbers for gaskets and seals etc.
http://www.stovebolt.com/techtips/ax...Ton%20Upgrade/
68 c10 LWB
Old 10-21-2015, 07:23 AM   #16
midniteblues
Thanks for the info guys. I know this truck will need brake work but not sure where the problem is.
are the brake parts hard too find? I really didn't look around yet since I'm not sure what's wrong with it.
Old 10-21-2015, 09:57 AM   #17
Motorfist
Drums are hard to find but shoes, wheel cylinders and spring kits are readily available.
If your drums are bad and you can't dig any up, there is a way to use 14 bolt brakes and axle shafts but it requires a little machine work. Some guys just swap in a 14 bolt axle at that point.
68 c10 LWB
Old 10-21-2015, 10:10 AM   #18
SoCoC10
SoCoC10's Avatar
Sold the center section/3rd member to a board member here. Someone can have the rest of it for FREE! Come get it! The housing, axles, brakes, brake cables, etc. FREE! Everything but the carrier, ring and pinion for FREE! Did I mention FREE!?
