Old 03-26-2014, 10:51 AM   #1
morethanstock66
morethanstock66's Avatar
My 1966 C10 SWB Fleet Build (Stacy)
Name:  After Buying.jpg
Name:  HEI, Carb, and Wires before tear down.jpg
After Buying
Name:  Empty Inside.jpg
Tear down for wiring and checking body..
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 03-26-2014, 11:01 AM   #2
timmytimm3
Re: My 1966 C10 SWB Fleet Build (Stacy)
Looks like a great truck to start with! I'll be following along
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 03-26-2014, 11:17 AM   #3
morethanstock66
Thanks, it'll be some work, but I have some big plans for it.
Name:  Pass Floor with Patches.jpg
Found this on the inside
Name:  Rusty Pass Side.jpg
With problems underneath... Needless to say pans and rockers on the way from Top Banana!
Name:  Gauge Cluster Work.jpg
Name:  Clean Cluster Back.jpg
While the interior is out, I thought I would take apart the gauge cluster and refurbish it.. Hopefully more to come soon
Old 03-26-2014, 11:32 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Cool truck! I like it! Looks like a great start!
Old 04-04-2014, 05:56 PM   #5
morethanstock66
Name:  Wires Inside.jpg
Name:  Wires Underhood.jpg
I've been busy due to work. I have a couple long nights and weekends ahead of me. Just taking my time and trying to do it right the first time. I'll have more progress and pics soon
Old 05-10-2014, 08:54 AM   #6
morethanstock66
Name:  Patched Wheel.jpg
Patched wheel yesterday.
Name:  Floorpan Templete.jpg
Cutting out cancer today and tomorrow.
Old 06-28-2014, 01:06 PM   #7
Xeen
Xeen's Avatar
Nice truck to start with, I'm not really a "green guy" but that dark green looks really nice I think it would grow on me.
Any progress lately?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-21-2015, 05:48 PM   #8
morethanstock66
I just realized I had not posted any status updates in a year, I am terrible. I have been busy working and scraping by to fix things on the old girl. Here are some updates, all after the fact of course.
Name:  TAKING TO GET FLOORS IN.jpg
Picking up where I left off, I took her to get floors done.
This is today, and very dirty, but very solid, and reasonable, as I can not weld well.
Name:  NEW KICK PANEL IN.jpg
Name:  NEW FLOOR SECTIONS IN.jpg
Name:  NEW DS FLOORS.jpg
Old 08-21-2015, 05:51 PM   #9
morethanstock66
Name:  new ds kick.jpg
Old 08-21-2015, 05:55 PM   #10
morethanstock66
Name:  NEW GASTANK.jpg
Next, I had to replace the fuel tank, I was having leaking from the filler neck on the inside, and from the sending unit. So it had to go, hence the new one.
Name:  OLD VS. NEW FILLER NECK.jpg
Look at the old plastic neck vs. the new metal one.
Name:  NEW BROKEN SENDING UNIT FITTING.jpg
New sending unit. "one more 1/4 turn.... SNAP!" New broken brass fitting. I sweat off the old HD brass fitting and soldered it back on, no leaks.
Old 08-21-2015, 05:58 PM   #11
morethanstock66
Name:  OLD FILLER NECK EXTENTION.jpg
Did I mention the old neck had a galvanized chain link gate tube as part of the neck? Who does this?! No wonder it took forever to fill at the pump.
Old 08-21-2015, 06:04 PM   #12
morethanstock66
One of my cartage drivers a work has a brother with an upholstery shop. So I had my old seat stripped, re-padded (with some extra foam), and covered in black fabric with black piping. For some reason it looks brown in the light though...
Name:  NEW SEAT IN.jpg
Put it in.
Name:  SOUTHERN ENGINEERED THROTTLE.jpg
Started it up to leave work one day and broke by spring return bracket, had to southern-engineer one to get home. I drove very slow haha
Name:  NEW THROTTLE BRACKET.jpg
Ordered a new bracket and put it on, much more reliable
Old 08-21-2015, 06:10 PM   #13
morethanstock66
Name:  NEW OVERFLOW TANK.jpg
I replaced an old NOS energy drink bottle with a new overflow tank, a little less spillage I think.
Name:  NEW STARTER INSTALLED.jpg
You can't really see it, due to heat shielding, but I put in a new higher compression starter so it turns over instantly. Can't beat Powermaster in my opinion.
Name:  NEW FUEL PUMP IN.jpg
Leaking fuel pump had to go, new one installed last month.
Name:  NEW FUEL LINE ROUTING.jpg
I routed new fuel lines while I was at it, Instead of a filter between the water pump and timing cover, now my big 'ol hands can change it with ease.
Old 08-21-2015, 06:16 PM   #14
morethanstock66
Name:  OLD DASH AND GAUGES.jpg
After I had a mech. oil pressure line leak on the ride home and blow out two weeks ago, I have been limited down to two working gauges. Only the speedo/odometer and head temp. Dangerous I know.
Name:  NEW GAUGES.jpg
So I got some new ones in this week and will be putting them in soon! I'm so excited.
Old 08-28-2015, 10:57 AM   #15
morethanstock66
Name:  CURRENT STANCE.jpg
So, driving to work yesterday, I heard and felt a huge snap coming from the front passenger side wheel area. Truck was still driving and braking. But the stance had dramatically changed.
Name:  BROKEN COIL SPRING.jpg
Turns out it was a broken coil spring. I got new shocks in and have new springs on the way for a 2"/3" drop, just a little lower with a slight rake. I will post pictures when they are in.
Old 08-28-2015, 11:14 AM   #16
Clyde65
Clyde65's Avatar
Sweet progress neighbor! ill be following!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-28-2015, 01:02 PM   #17
CRGRS 66
CRGRS 66's Avatar
Nice 66 brother! I like that you are driving it while you making your improvements.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 08-28-2015, 04:23 PM   #18
morethanstock66
Thanks guys! She is my daily driver, so my tweaks are usually a lot of little steps instead of doing big projects all at once.
Old 08-29-2015, 11:43 AM   #19
scuderia
scuderia's Avatar
Originally Posted by morethanstock66 View Post
Attachment 1441131
Attachment 1441133
Also thinking of a 2/3 drop for mine. Which springs and shocks are you going with? Will stock length shocks work with 2/3? thanks
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 09-04-2015, 11:52 AM   #20
morethanstock66
I thought about it with the old suspension in mind, OE springs with new shocks works. OE springs will sag over the course of 49 yrs. So I sort of gambled with it. Turns out they work, and work well. I used CPP 2/3 drop springs, with OE length shocks.
Name:  NEW FRONT SHOCK AND SPRING.jpg
Here is the new front shock and spring.
Name:  NEW REAR SHOCKS AND SPRINGS.jpg
New rear shock and spring
Old 09-04-2015, 12:02 PM   #21
morethanstock66
Name:  OLD BROKEN SPRING.jpg
So the old spring actually broke in two places. The broken part equaled 2 full coils.
Name:  NEW PS STANCE.jpg
CPP 2"/3" drop springs, OE length local parts house shocks, OE a-arms and trailing arms.
Name:  NEW DF STANCE.jpg
I may play with the stance in the future.. but right now, I am satisfied.
Old 09-28-2015, 08:44 AM   #22
morethanstock66
So, about a week and a half ago, I finally got around to pulling the old dash and trying to put in the new one.
Old set out.
Name:  EMPTY DASH WITH OLD CABLE.jpg
Then the wiring began..
Name:  HANGING ACCESSORIES.jpg
About this time you start to think that it may be a bad idea with work the next day haha
Name:  HOOKING UP NEW SET.jpg
Getting everything up and seeing the light at the end of the tunnel
Old 09-28-2015, 09:20 AM   #23
morethanstock66
Name:  Finished Cluster.jpg
I was going to upload a video of me starting it and everything working, but the conversion process from .mp4 to an approved file type made it look like garbage. So, here is a quick pick of it in, as of five minutes ago
Old 09-28-2015, 10:07 AM   #24
TJ's Chevy
TJ's Chevy's Avatar
New dash cluster looks nice.
Old 09-29-2015, 05:04 PM   #25
morethanstock66
Thanks TJ, it is so much different having a full set of gauges that actually work
