Old 11-12-2015, 11:54 AM   #1
johndawelder
johndawelder's Avatar
side glass
What do I need to do to put one piece windows in the doors of my 52.I don't want vent windows in it anymore.I am putting power windows in it also.
johndawelder is offline   Reply With Quote
Old 11-12-2015, 12:25 PM   #2
mr48chev
mr48chev's Avatar
Re: side glass
Simple way would be to get 47 50 doors and swap them out. to convert the windows you need to cut out the piece of metal that is right under the wing window after you remove the wing window assembly.
This is a door like yours with the wing assembly removed.
This is a 47/50 door with the glass removed.
One "have to have" for the swap is the metal channel that the glass channel runs in at the front of the doors.
Chevs of the 40's has those new and maybe another vendor or two but a lot of vendors don't show them in the catalogs and they are usually missing from doors you find in the wrecking yards.
My ongoing truck projects:
Old 11-12-2015, 03:58 PM   #3
johndawelder
Re: side glass
My doors have already been chopped by previous owner,so using another set of doors probably would just make more work for me.I can make the channel that I need.Do I need to make the channel that goes on the glass inside the door longer?
