Diggin The SquareLife
fittings for hardline
im going to be running accuair setup and going to be mounting it in the bed of my truck and I want to run hardlines from the vu4 into my bed floor, an replace the leader hoses from the compressors to the tank with hardline and any other lines that will be seen in the bed, I need help finding fittings for the hardlines to do all this as im not finding anything online an im getting diff answers from ppl just wanted to get going in the right direction with fittings and where to get them....I want it to look like the setup in the pics
![]() Join Date: Jan 2011
Re: fittings for hardline
One picture looks like they are using Swagelok fittings. https://www.swagelok.com/ The other is a straight flare fitting. If you have a Parker Store in your area they will have both types.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Jul 2015
Like PGSigns said, if you have any hydraulic supply place near you I'd take a ride up there and they should be able to hook you up.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
![]() Join Date: Oct 2012
Like the others have said, top is push to connect fittings, middle is swagelok fittings and bottom is AN 37degree flare fittings.
I'm using AN fittings and the cheapest place I've found was www.anplumbing.com all are good fittings it just depends on the look you're after and budget. |
#5 | |
![]() I was going to put braided line and AN fittings on my bike oil lines a few years back and quickly was like NOPE, it's not that nice a bike ha!
thanks for the reply guys!
think im going to use the Swagelok fittings an maybe a few of the parker ones also
Parker makes all three styles and you should have one in your area.
Jimmy
#9 | |
meowMEOWmeowMEOW
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
