Old 11-07-2015, 01:33 PM   #1
WB72
Before and After
WB72's Avatar
New style A/C unit from 1990 into 72 non A/C truck
Fellas,
I'm sure this is on many of our minds, and maybe it has been covered, but my searching online abilities are low.
Is it possible to add Air conditioning from a 1990 Silverado into a 1972 Non-air truck?
The reason I Ask, is I have a 1990 donor truck with A/C at my disposal. I'm wondering if it is possible to make it work, and if it is, how much work and modifications are required.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 11-07-2015, 02:34 PM   #2
Bigdav160
Bigdav160's Avatar
Re: New style A/C unit from 1990 into 72 non A/C truck
I've never put a tape measure to it but I'd assume there isn't enough room under the dash of the older trucks
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-07-2015, 02:40 PM   #3
dmartin1
dmartin1's Avatar
If your handy at fabricating you could problem fab up the compressor,lines,and condenser up front.
The dash stuff would problem be quite hard.
If you could use the engine bay stuff from the 90 and get yourself an underdash unit you may be able to make it work.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
