Old 11-04-2015, 02:27 PM   #1
WarMonger
WarMonger's Avatar
AVS C-Notch Anyone using or have pics?
Wondering if anyone is running this set-up? Didn't seem bad for 150? Looks like you can put it over the frame, weld it in, then cut your old frame piece off and weld in the underside.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 11-04-2015, 03:18 PM   #2
mandojunior
Re: AVS C-Notch Anyone using or have pics?
I installed one from avs but it wasnt 67-72 specific. It looks the same tough. And you are right, you mount it on your frame, weld it in and cut the middle off. I beleive its 3/16's thick.
mandojunior is offline   Reply With Quote
Old 11-04-2015, 03:46 PM   #3
WarMonger
WarMonger's Avatar
How did you like it? It looks pretty good to me?
1970 C20
-_--_--_- ______
1972 K5
Old 11-04-2015, 03:52 PM   #4
mandojunior
It was pretty good. I think most companies sell them in 3/16's thick. Just make sure you weld some sort of crossmember at the top, since you have to cut out the stock crossmember. I just used two sticks of 1 1/4" round pipe and welded them inside the top corners
Old 11-04-2015, 03:53 PM   #5
mandojunior
Installing it was pretty straightforward and quick too
