Old 11-01-2015, 04:21 PM   #1
72farmer
Changing drums to disc's which year tie rod to order?
I have a 67 that I am going to change to disc brakes.I am trying to get my parts together.I am going to rebuild and use my original 67 compontents.I already have a set of stock height spindles off of a 72.If I read the tips correct I need to order my ball joints for a 72 and my tie rods for a 67.
Is this correct?My truck has been lowered about 4".I am going back to original stock height.I have priced coil springs and shocks.Will I have to have another rear track bar to get it back to stock height?
72farmer is offline   Reply With Quote
Old 11-01-2015, 05:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Changing drums to disc's which year tie rod to order?
Everything has to match the year of the spindle.
The easiest option would be to buy 63-70 conversion spindles.
Then everything on your truck will be a direct bolt on.
You open up a can of worms switching to 71-72 spindles.
Keith
Convert to disc brakes.
Old 11-01-2015, 08:15 PM   #3
72farmer
Well I just thought I had a plan.What procedure would it take to use the 72 spindles?
Old 11-01-2015, 08:50 PM   #4
72farmer
I just gave $60 for the pair of spindles.I guess I jumped the gun.
Old 11-01-2015, 08:51 PM   #5
lolife99
lolife99's Avatar
You need 71-72 balljoints and outer tie rods.
The 71-72 outer tie rods don't work with the 63-70 inner tie rods. Wrong diameter and thread pitch.
So you need either:
1) all 71-72 steering including the center link.
2) move your 67 outer tie rods to the inner location. Buy a $50-60 tie rod adapter to connect to the 71-72 outer tie rods.
All of this is in my thread at the top of the suspension section.
Buy conversion spindles!
Direct bolt on!
Nothing to change.
Stock or drop.
$229.
Every spindle company makes them.
Or get a complete 71-72 or 73-87 assembly and rebuild that.
The conversion spindles make it easy!
I wouldn't give $1 for stock spindles.
You need new bearings rotor calipers and brake components.
Keith
Old 11-01-2015, 11:15 PM   #6
SoCoC10
SoCoC10's Avatar
72farmer If you decide to continue with the spindles you bought, I have a pair of brand new tie rod adapters I never installed. PM me if you are interested.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 11-02-2015, 09:49 AM   #7
67 cst swb
67 cst swb's Avatar
use everything off the 72, spindles, ball joints, tie rod ends (inner and outer) centerlink, pitman, idler (yes these are the same as 67, but you get the idea).
Think of it this way... you now have 72 front suspension, use all 72 stuff. the centerlink is 71-72 only and will need this to get the correct inner & outer tie rod ends.
There are other ways to go about this, but the 71-72 centerlink and 72 spindle is the easiest. That is... if you want stock height spindles and can locate a 71-72 centerlink as they are not reproduced.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 11-07-2015, 07:33 AM   #8
72farmer
Thanks for the knowledge.My plan is to use the 72 spindles and the center link from my donor truck.Buy a disc brake kit just don't know where to go 5 or 6 lug.
Old 11-12-2015, 10:39 PM   #9
Possmguts
Possmguts's Avatar
without reading through all this... I also have a 67 I lowered. CPP has an UPDATED drop spindle that uses the ORIGINAL tie rods along with the original center link... and will use the 71-72 rotors and calipers...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
