![]() Join Date: Jul 2013
AT crossmember correct?
I can't tell if I have the crossmember in the correct location or if it's upside down. I still need to swap the new mount with the rubber on the trans itself
Re: AT crossmember correct?
It appears to be upside down to me, seems it would fit better the other way, try it...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#3 | |
1970 C10 Short Stepper with 71/72 front clip. |
![]() Join Date: May 2014
I think it's upside down too. I just installed a tubular one yesterday. Never saw one like yours. The tubular one I have is nice because it's got better clearance for exhaust pipes. It was $72 to the door on evilBay.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
I was thinking it was upside down too...can you post a pic of your tubular frame? I got mine as a complete kit, tubular motor mounts and the crossmember you see in the pics
This is the one I have.
Any chance you have one of it mounted?
No but the next time I'm under there I can take a picture.
Your transmission crossmember is correct. I believe that's a gmc Paul crossmember. The ends that mate to the frame are a C channel right? If you flipped it over the trains would be above the top of the frame. Your pictures ( or truck) however, are upside down.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Not sure if the gmc Paul but yes on the c channel. I put a pic of the kit I bought. It fits great but came with zero info and I don't wanna have to pull it all apart bc it's upside down :/
![]() Join Date: Jun 2011
put mine in yesterday. and the flat side on the trans mount is level with the upper frame rail. I hope that is correct. My frame is completely bare, I have nothing to go my except memory
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
Now that I see a good picture of the mount you and the OP have I believe his is mounted correctly and that yours is mounted incorrectly.
So I've seen both answers, should the flat side be sitting flush with the top rail or drop down?
It definitely can't sit flush with the top rail. Your transmission tail housing would be pointing WAY high.
#16 |
I guess I better change mine today, before I go any further. Thanks for the pictures.
#17 |
Here's a picture of mine as requested.
