Old 08-22-2018, 07:38 AM   #1
65truckowner
65truckowner's Avatar
wtb shifting rods from a 67-72 3 speed
I am needing a set of shifting rods from a 67-72 c10 with the 3 speed on the column price shipped to 72560 Thanks
65truckowner is offline   Reply With Quote
Old 08-22-2018, 08:11 AM   #2
shoveldug
Re: wtb shifting rods from a 67-72 3 speed
i will ship you a set for $50 total. They are from a 6 cyl truck saginaw transmission.
shoveldug is offline   Reply With Quote
Old 08-22-2018, 08:26 AM   #3
southern parts
southern parts's Avatar
6 cyl. or V8 ?
southern parts is offline   Reply With Quote
Old 08-22-2018, 08:58 AM   #4
65truckowner
Originally Posted by southern parts View Post
6 cyl. or V8 ?
I have a 65 c10 with a 68 3speed in it with a 350 the rods I have won't fit someone said the 67-72 six engine trucks would work
Old 08-22-2018, 09:40 AM   #5
southern parts
The rods that shoveldug has should work for you.
Old 08-22-2018, 05:02 PM   #6
65truckowner
Do you have paypal
Old 08-22-2018, 10:57 PM   #7
If nothing works out I have a bunch of the rods. But they are all mixed up and I'd need help sorting out what is what
Old 08-23-2018, 06:18 AM   #8
shoveldug
Originally Posted by 65truckowner View Post
Do you have paypal
Yes I do. It is dwl65101@yahoo.com I also sent you a PM
Old 08-23-2018, 07:31 AM   #9
65truckowner
Ok money sent Thanks
Old 09-01-2018, 07:44 PM   #10
65truckowner
Just a heads up the shifting rods from a 67-69 chevy truck will not fit a 65 with a 68 3 speed transmission
Old 09-01-2018, 08:33 PM   #11
Those were 67-72 6cyl rods for 3spd, correct? And you are saying those will not work on a '65 with V8 and 3spd. So have you tried 60-66 V8 rods for 3spd? Is the engine mounted in the 6cyl position (dist. back into the firewall) or the V8 position?
Old 09-01-2018, 09:10 PM   #12
65truckowner
They will not work on my truck. I have a 350 with a 68 3 speed. The truck is a 65. The rods are too short and will not clear the firewall and the clutch z bar. I was under the truck a while trying everything to make them work. I have not tried the 60-66 v8 rods. I think the engine is in the 6 position but not sure. The original bell housing was in the truck when I got it bolted to the factory cross member right behind the engine.
Old 09-02-2018, 10:45 AM   #13
southern parts
Are the engine frame stands in the front or rear holes? How much room between the distributor and firewall?
Old 09-02-2018, 09:08 PM   #14
65truckowner
The back holes but like I said the bell housing is bolted to the front cross member. It cannot move forward to my knowledge Any way I went today to buy a tranmission and driveshaft from a guy and ended up buying the whole truck so I will have everything I need to put the right 3 speed in it
