Old 11-29-2015, 07:05 PM   #1
72 Cheyenne K20
Eaton Rear End ID Question
Hi Guys, I just bought a 71 3/4 ton 4x4 with 350/sm465/np205. Checked the F & R ends today and wanted to ask if anyone knows the factory codes for axles. from what I can see, the code on the Eaton is TJH and followed by G 1172. From reading some other posts,I think the TJH is correct for 71 but have no idea what the G 1172 is for. Also, what's in the red square?
Thanks for any help you have to offer, Scott
72 Cheyenne K20 is offline   Reply With Quote
Old 11-29-2015, 07:46 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Eaton Rear End ID Question
The item in the red square is -- if I get the terminology correct -- the pinion preload bolt. It is on all HO72s (1 ton) and some HO52s (3/4 ton).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-29-2015, 08:06 PM   #3
72 Cheyenne K20
Thanks Stocker, I had read about the pinion preload bolt in other posts but wasn't sure if that's what it was. I need to get the ratio code from the axle tomorrow. I thought for sure it would be 4:56 in the Eaton. But, I looked at the Dana 44 in front and it has a 4:09 ratio tag on it. I thought the 4:09 only came with the automatics.
Old 11-29-2015, 08:20 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
What little I know about them, 4.10 seems to be a very common ratio. Easy enough for you to verify though.
- Mike -
RIP El Jay
Old 11-29-2015, 08:26 PM   #5
jocko
jocko's Avatar
TJH = 71 k20 4.10:1 (Edit: also non-posi)
Old 11-29-2015, 09:02 PM   #6
72 Cheyenne K20
Thanks Jocko, that helps a lot. Nice to know she's all original.
Scott
Old 11-29-2015, 10:04 PM   #7
mtdave2
newly minted old timer
mtdave2's Avatar
looks like mine. Eaton axle. Apparently there are not many parts for these, and it is a non-posi. so I will be swapping the thing out before long.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 11-30-2015, 12:03 AM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm glad I kept the HO52 in my K20 - it was rebuilt and parts weren't hard to locate. Two weeks ago a local parts store had shoes and seals for the HO72 in my C30 sitting on the shelf.
Old 11-30-2015, 10:16 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Here is a thread I posted with the charts if any one else needs to look up the codes.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc
Leon
Old 11-30-2015, 11:41 AM   #10
j_cst_10
j_cst_10's Avatar
My father in law has an eaton with a Detroit locker set up (I believe). I was thinking about picking it up, are these hard to come by with the locker? Might use it in a project of mine.
j_cst_10 is offline   Reply With Quote
Old 11-30-2015, 12:00 PM   #11
72 Cheyenne K20
Thanks LockDoc! Do you have a chart that shows Dana 44 BOM numbers. I located the #'s from mine and can't seem to match them up with any of the #'s listed. My BOM is 603317-8. Along with 4 1 1A4 to the left of the BOM and 4 7 1A8 above the BOM. I've seen this number here in a different post but nothing in Dana material. Any help identifying would be great.
Thanks, Scott
Old 11-30-2015, 12:04 PM   #12
mtdave2
mtdave2's Avatar
if you find a place that has the locker parts let me know. I was told they are very hard to find. id much rather pull the guts out and make it a posi than swap axels.
yeah, the brakes and such are availible. I am talking the actual gear parts are hard to find.
69 k10 Suburban
Old 11-30-2015, 12:59 PM   #13
LockDoc
LockDoc's Avatar
Thanks, Scott
No, sorry I don't.
LockDoc
Leon
Old 11-30-2015, 09:35 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
No new gear parts to my knowledge either. I was fortunate to get a NoSPin locker from a member on the parts board.
Old 11-30-2015, 09:39 PM   #15
swamp rat
swamp rat's Avatar
I have some charts saved in my saved files but i'm at work at the moment, i'll try and get it posted here spmetime soon.
Most parts are still avalable with the exception of the ring and ponion, last i chacked tho the bearings inside the diff were really expensive, but the eatons are nearly indestructable.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-30-2015, 09:54 PM   #16
swamp rat
swamp rat's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=590959
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
