Old 11-29-2015, 02:14 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Next up remove the Heater Box - Seeking education
71 C-10 tear down - all new to me
1. Wire harnesses & receptacle: Can you describe each of the two plugs mounted onto the RH side of the heater box? What are they called, and what's the receptacle unit called? Edit: It's the Blower Relay.
2. Heater core hoses (5/8" inlet, 3/4" outlet). I'd like to keep this running as long as possible. There's a lot of confusing information for bypassing "the" heater core. If I plug the ends of each hose, does that create a recirculating concern? Suggestions? It's only temporary, and the truck doesn't even leave the driveway.
3. Why do I see two heater cores......WTH? Edit: Ah, Evaporator Core....Yeah, I'm pretty green.
4. Other than good notes, pictures and the obvious, (I won't reassemble this for two years plus),any suggestions for removal? Should I remove the evaporator core assembly before the heater box?
Thanks for any advise.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
