Help with 283
It sucks to start on this forum with a question, but help is needed!
I own a 1966 c10 with a 283 small block, built. A couple days ago, I was soldering my wire connections to a tachometer. Being stupid, i didn't disconnect the battery leads, and shorted the ignition wire to the key with the fan motor briefly. thought nothing of it, fuses were all good. I accidentally pulled wires loose out of the ignition key, no problem, I re attached them, figured the case unrelated to the following scenario unless someone deems otherwise. I went to start the truck, all it would do was crank over. I replaced the coil, figuring no spark. Battery at 12 volts. Still nothing. It got worse, now the starter would't even crank the motor over at all, just rapid fire clicking noise. I assumed I flooded the motor, gas was leaking out of the carb gasket. I waited an hour, then it cranked to life, but it was cold enough out that it died after a few seconds. I tried to start again, this time the starter wouldn't even crank the motor over again. The engine bay smells like gas. The oils smells like gas, it did slightly a few days before, meaning to do an oil change (still has plenty of oil in it) I'm assuming the starter solenoid went out, or starter is jammed on the flywheel; weird thing is that it did start once. I cleaned off the battery starter terminals, no luck. Hopefully I didn't hydraulic a cylinder. I also couldn't get a breaker bar on the front of the motor to see if it turned over manually, didn't have time to take the balancer off (fairly certain it has to). |
Re: Help with 283
sure sounds like your getten raw gas down the intake. pull the plugs and turn it over to clean it out. then see if it starts.
![]() Join Date: May 2015
Re: Help with 283
IM in the same situation with my 283 in my 66 C10! I have been chasing down timing because I know it was never timed right, but now it is like the motor is siezed up or something!
Re: Help with 283
It has been years but my first truck was a 66 with a 283. It use to go through starter solenoids. I assumed it was from heat from the old centre drop exhaust manifold and not having proper heat shielding in place. Anyhow it would get like that and I would have to replace the starter solenoid. Not sure if that is your problem but it sounds like the problems I was having. Good luck.
Re: Help with 283
Sorry just to clarify it would clunk and not turn over or it would click like the battery was dead. Even though I had good a good battery.
#6 | |
Re: Help with 283
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
Re: Help with 283
If you are getting that much gas into the engine you may have a carb. flooding or a bad fuel pump. Check the dipstick to see if it is overfull.
Tags |
1966 chevy c10, 283 v8 |
