Old 11-16-2017, 04:22 PM   #1
yote1234
yote1234's Avatar
pics of 2 or 2 1/2 inch lifts and give tire size
I Am looking to drop my 84 Silverado down from 4" to 2 or 2.5 " with maybe
32x10.5x75r 15;s . this 84 I have RANCHO 4" and 33x12.5r 15's for over 30 years and now getting older and want a softer ride and lower it so its easier to get into!. heres the truck now.
I thank you all,dave
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 11-16-2017, 08:49 PM   #2
b454rat
Re: pics of 2 or 2 1/2 inch lifts and give tire size
Put some steps on it, and get a good suspension system. I thank Rancho is thee stiffest out there.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-17-2017, 09:28 AM   #3
sweetk30
sweetk30's Avatar
tuff country is about the best off the shelf for price / ride / quality .
or call www.offroaddesign.com and have a set of there custom spec built springs made .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-17-2017, 11:02 AM   #4
yote1234
yote1234's Avatar
agree. but was a good choice 30 yrs ago.. thx for reply,
think i like skyjacker soft ride. 2.5 maybe. with either 31x10.5 75r or 32 11.5 75r ?
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-17-2017, 11:51 AM   #5
BLT gmc
I run the Skyjacker 2.5 springs frt and back on my '69 GMC 1500. Overall I am satisfied with their performance. I live on a small farm and use it for farm activities, some off-road stuff like going through cornfields rounding up cattle. I would like to post some pictures but don't have any right now. I run a stock 16 inch steelie. Hercules Traildiggers I think they are 31".
BLT gmc is offline   Reply With Quote
Old 11-17-2017, 03:42 PM   #6
b454rat
If ur running a lift then you don’t want to run 31s, they came stock with them and would look goofy with any lift n small tire. 32 lil better but still small for lift.
Old 11-18-2017, 11:07 AM   #7
yote1234
yote1234's Avatar
thx for the reply b454rat. I found out these came with 235x75xr15 and I did a comparison between the factory tire and 31x10.5xr15, looks to be a bit different. chart below... thx for your reply, dave
https://tiresize.com/comparison/
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-18-2017, 10:30 PM   #8
Matt Man
Matt Man's Avatar
On my 81 the best thing I did for the ride was put a adjustable shock on and dumped the quad shock setup. I installed procomp mx6 shocks and it was night and day difference, my truck also has the 4" Rancho lift. However, if you really want to drop to a 2.5" lift I would get the tuff country EZ ride springs.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-19-2017, 07:39 AM   #9
b454rat
If you want to go with a mild lift, you could run stock springs with a long add a leave, a zero rate and longer shackles. With the add a leave, it will be slightly stiffer, but better than the springs currently have. Or could do 52s, but that might be more lift than what you want/need.
Old 11-20-2017, 11:54 AM   #10
yote1234
yote1234's Avatar
I thank you both for the advice. its very helpful. now on the 52" spring? not sure what that is all about? my rear factory springs are 52" eye to eye. dave
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-20-2017, 02:09 PM   #11
sweetk30
sweetk30's Avatar
offroad flex and cheep 4" lift in the front is to use 52" rear springs with a set of hangers on the front .
your use of the truck dosn't require this mod .
Old 11-21-2017, 11:46 AM   #12
abig84
abig84's Avatar
i fell into the same situation a few years back, they pretty much shut down all the local off road places and needed new tires soon. so figured whats the point of buying new 38s that are never going to see snow.
i basically just put the stock suspension and and put on a 2 inch body lift
before
33 12.50s on 2 inch lift
apparently i should have bought a better camera back then. for some reason thats the only two pictures i have after lowering it
abig84 is offline   Reply With Quote
Old 11-21-2017, 06:11 PM   #13
yote1234
yote1234's Avatar
thank you all for the interesting info,... leaning tward 2.5 inch all spring on
31x10/5 xr15
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-21-2017, 06:16 PM   #14
BLT gmc
FWIW- Have you considered a six lug 16 steelie widened to 8 inches. I think these rims make a 1/2 look like a boss, but as you probably know these rims are not just hanging around. Bruce
Old 11-22-2017, 11:16 AM   #15
yote1234
yote1234's Avatar
I just got my orig ralleys powder coated, will be using them.
thx for the input, dave
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-22-2017, 08:58 PM   #16
Willowrun
Willowrun's Avatar
31x10/5 xr15
I think 31's would look too small with 2.5".
My Blazer is 2.5" Tuff Country front leafs and a 3" block in the back with 33x12.50x15.
Old 11-22-2017, 09:01 PM   #17
Willowrun
Willowrun's Avatar
Stock height K10 with 31's
Old 11-25-2017, 04:05 PM   #18
Sweeet67
Here is my 69 with a 2” lift. I have 33x11.50r15 on it right now. I do get a slight amount of rub if I’m on the stops and hit some bumps.
Sweeet67 is offline   Reply With Quote
Old 11-26-2017, 11:01 PM   #19
tim71
tim71's Avatar
Still a few weeks away from completion of build. Truck has a 2" Tuff Country spring lift, that seems more like a 4" lift. It turned out higher than I wanted. The tires in the picture are 33x12.50's that only measure 31.2 inches with weight of truck on them.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 11-30-2017, 12:06 AM   #20
CG
BlahBlahBlah
Really like the colors of your truck. And you are right, that does look like a four inch lift from the pictures.
Old 12-08-2017, 11:12 PM   #21
GSP7
GSP7's Avatar
2 1/2 " blocks on rear of 3/4 ton camper special.
4" front sprgs, 35 " tires
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 12-11-2017, 01:00 AM   #22
bmchevy1979
bmchevy1979's Avatar
This is an old Rancho 2.5in I had in my 74 with 33x12.50r15 on 15x8s
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-24-2017, 12:50 AM   #23
86454k30
86454k30's Avatar
Pretty sure this was 2" lift, 33x12.50 on 15x10 ralley.
86454k30 is offline   Reply With Quote
Old 12-26-2017, 09:43 PM   #24
RedRoad
RedRoad's Avatar
There are new 15x8 steel wheels available.
http://www.67-72chevytrucks.com/vboa...d.php?t=753217
Originally Posted by 1966 K10 View Post
anyone try these new wheels from Wheel Vintiques?
https://www.wheelvintiques.com/wheel...ed-finish.html
Cant beat the price at $84 for 5.5", $87 for 7", $88 for 8", and $107 for 10"
Takes stock cap too!
If enough people show interest Summit will carry them and then you get free shipping!!!
RedRoad is offline   Reply With Quote
