Old 01-07-2016, 04:43 PM   #1
davepl
davepl's Avatar
Cup holders instead of seat belt holders
I've seen console reproductions with cup holders, but I'm wondering if my original console can accommodate cupholders instead of the belt holders. Someone on another thread said it was 2 screws, so that doesn't sound like it would be the whole top half.
What part of the console changes, and how invasive is it, and where do I get the cupholder part?
Thanks in advance for any info! I'm sure I'll make a lot more use out of cupholders than selt belt holders, especially since I have 3-pt retractables now.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-07-2016, 04:47 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Cup holders instead of seat belt holders
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-07-2016, 05:21 PM   #3
FirstOwner69
FirstOwner69's Avatar
I've got a couple consoles of each type, but they're about 2000 miles away, so I can't compare them side by side.
If I recall correctly, the seat belt portion of the early consoles is integral (molded into) the top portion of the console. The cup holder portion of the later consoles is removable and held in place by 2 or 4 screws. You MAY be able to surgically remove the seat belt portion and add the cup holder portion, but I think some additional fabrication may be necessary to support the cup holder portion. Since the hinged tops and chrome trim rings are the same size, it's reasonable to assume the front section housing the cup holders would be the same size as the seat belt section.
I've seen billet cup holders to replace the factory cup holders, but I think you'd need to buy the factory cup holder section used.
Maybe someone would trade top sections with you. I know I would.
EDIT: Here's a link to a parts thread that has pictures of both types for comparison. http://67-72chevytrucks.com/vboard/s...hlight=console Also... the cup holder consoles use a different hinge for the lid.
Jim
FirstOwner69 is offline   Reply With Quote
Old 01-07-2016, 05:55 PM   #4
frankslagoon
the console in my trk has cup holders. it sits in there with a couple screws. bad news is ya got to take the chrome strip off, which is doable but a little tricky. maybe the older consoles are one piece. All the blazer guys have these consoles. maybe check on the blazer forum.
frankslagoon is offline   Reply With Quote
Old 01-07-2016, 06:14 PM   #5
67 chevelle
67 chevelle's Avatar
I used this
http://www.usa1industries.com/1967-8...r-console.html
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-07-2016, 06:46 PM   #6
lowrodderchev
lowrodderchev's Avatar
I cut my seatbelt console to use a cup holder drop in, its 2 screws
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 01-07-2016, 06:50 PM   #7
lowrodderchev
Old 01-07-2016, 07:27 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Cup holders instead of seat belt holders
This is a link to mine. I put the new billet cup holder in mine.
Taking the trim off wasn't so bad with a good peir of needle nose. Twist the tabs and it pops off.
http://67-72chevytrucks.com/vboard/s...d.php?t=648379
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-07-2016, 08:33 PM   #9
FirstOwner69
Dave, this would look good in your truck. It's on forum member t korinek's Craigslist ad in Phoenix. I wonder if it's still available.
http://phoenix.craigslist.org/evl/ptd/5391516118.html
Jim
