Glove Box decal insert???
I've got a chrome glove box with the black insert decal that is chipped. I've called 6 or 7 suppliers to find this...Anyone know where I can find it...My gauge panel is also the same black decal insert...Any help would be greatly appreciated...Greg
![]() Join Date: Oct 2008
Re: Glove Box decal insert???
Repop gauge clusters are available from just about all the vendors. I do not believe you can buy an aftermarket / repop black sticker with the correct texture -- I haven't seen one. I suppose you could buy a woodgrain one and spray it with black plastidip... Or I've seen people just spray the glovebox itself
Hope this helps |
![]() Join Date: Oct 2009
Assume you're talking about a 67? If so, here are some interesting threads for reference - 1st one is about a way to match the correct texture. I don't believe anyone sells a decal. Also, Chev never sold a chrome glovebox door - so you'll need to scuff it if you're trying to get a texture on it and have paint stick. 71-2 Chevs did have an aluminum tray insert that held the woodgrain for a Cheyenne Super, but the rest were painted. 67 was unique. Hope this helps! Excerpt from 1st thread below - it's a great read.
http://67-72chevytrucks.com/vboard/s...d.php?t=592128 http://67-72chevytrucks.com/vboard/s...d.php?t=692540 Last edited by jocko; 12-31-2015 at 09:37 PM. |
Thanks, I may try to paint a woodgrain decal...
I've got a '69 cab with '67 front clip...When I purchased the truck, It came with a Chrome
glovebox door with a black insert glued to it...However the insert has a small piece missing...Appreciate all input...Greg |
I had a CAD drawing made of both a dash bezel and a glove box door made, it's now on the FAQ pages. if you take that .dwg file for both, to a laser engraver, they can cut out a perfect sized piece of sheet plastic that you can apply to both your glove box and dash bezel. The dash bezel I had made was for gauges though, didn't know if you had them or not. Guess I'll have to look into getting another drawing made for the guy's without gauges.....here's a few pictures:
http://67-72chevytrucks.com/vboard/s...d.php?t=691061 Enjoy! Ben Smith ![]() |
Hi, I just did this project. I got a new instrument panel for Christmas and wanted to do a matching glove box lid. I bought a chrome lid from LMC. There are no decals out there to buy, so I went to Home Depot and bought some Faux Leather Black contact paper (shelf paper). It matches the grain and color of the new instrument panel very well. I taped it to the lid to create a template to match. I applied the contact paper to the glove box lid, using a hair dryer to heat/stretch the contact paper to fit at the lid lock hole. Installed in the truck...looks great and matches the instrument panel!
that looks very nice kowtown! thanks for sharing.
R56 - if you are looking for a woodgrain insert, those ARE available. Sometimes hard to find, but out there. |
Instrument panel and glove box lid installed. Job complete.
what steering wheel is that?!!?!?!
i didnt know comfort grips were available in colors!!! |
That wheel was probably painted with vinyl paint to match.......
Ben ![]() |
#12 | |
Kowtown, Looks great....I'll give it a try....
Kowtown, Quick question?...Did you use an exacto knife to cut the contact paper?...
#15 |
That steering wheel is from National Parts Depot. It is a 1967 Camaro walnut grain steering wheel and adapter hub. The wood grain was filled, wet sanded and painted to match the interior of the truck. The tilt steering column is from CPP.
#16 |
#17 |
Kowtown, Thanks for the info...
