Old 01-09-2016, 09:37 PM   #1
hemi43
hemi43's Avatar
Door weatherstrip
I'm just installing the door weatherstrip, and didn't know if there was supposed to be some sort of cap covering the end at the box? I guess if the hard top was on you wouldn't see it, but with a soft top it looks unfinished.
hemi43 is offline   Reply With Quote
Old 01-10-2016, 12:10 AM   #2
1rippen6
Re: Door weatherstrip
I think I saw a cap for that in the LMC catalog.
1rippen6 is offline   Reply With Quote
Old 01-10-2016, 12:26 AM   #3
hemi43
hemi43's Avatar
Thanks, I'll try and find it.
Old 01-10-2016, 12:39 AM   #4
1rippen6
Item 12
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=39
Old 01-10-2016, 05:56 PM   #5
tjsblazer
tjsblazer's Avatar
I think it is a plug type thing.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-10-2016, 08:47 PM   #6
hemi43
hemi43's Avatar
I'll check with Bill's trucks in the morning. I never think of checking LMC because it's just too expensive for us north of the border especially now that an item that costs $1.00 US will now cost us $1.42 because of the exchange rate, and then we have to add shipping, brokerage, taxes... I'm too old now, but if I had to do it over again I would have moved to the States when I was young.
Old 01-10-2016, 08:54 PM   #7
jaros44sr
jaros44sr's Avatar
JMO, but if you plug it, where will the air go when you collapse the weatherstrip. Could make it hard to close the door
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-10-2016, 09:32 PM   #8
1rippen6
Bill's truck is awesome I bought my sliding hard top windows from him for 80 dollars US.
Old 01-10-2016, 11:39 PM   #9
hemi43
hemi43's Avatar
Good point, but if they came from the factory, you would think they'd be OK.
Old 01-11-2016, 08:32 AM   #10
jaros44sr
jaros44sr's Avatar
that's just it, I've never seen it. But, a cover would work. When the door is closed doesn't it pinch it shut, dunno
SAFETY FIRST
AS usual, off topic
Jim
Old 01-11-2016, 10:07 AM   #11
Minnz
Minnz's Avatar
The Chevy parts catalog shows a plug there (page 17-6). It must have been made of a softer material than the plugs sold by LMC. The LMC plugs that I tried are too hard and usually pop out when the door is closed.
72 Ochre Blazer
69 Camaro Z28 Garnet Red
48 Willys (rolled)
Minnz is offline   Reply With Quote
Old 01-11-2016, 10:55 AM   #12
1rippen6
They may have been glued in
Old 01-11-2016, 11:39 AM   #13
ls1nova71
ls1nova71's Avatar
They weren't glued in from the factory, at least mine weren't. Kind of wish the were so I wouldn't have lost one by blowing it out with the pressure washer. This is my remaining one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-11-2016, 03:02 PM   #14
hemi43
hemi43's Avatar
I just picked some up today. I'll glue them in but all the way around to let air escape. I'll post a pic once installed. Thanks for the replies !!
Old 01-11-2016, 07:53 PM   #15
Minnz
Minnz's Avatar
What is the material of your plugs?. My LMC plugs are made of hard rubber, definitely not like the originals shown above. When inserted without some sort of cement they literally launch 15 feet across the garage (LOL ) when the door is closed. When glued in they inhibit the closing of the door..... curious to see what yours do.
72 Ochre Blazer
48 Willys (rolled)
Old 01-12-2016, 10:24 AM   #16
jaros44sr
jaros44sr's Avatar
The way ls1novas is designed makes sense, if you glued the tab in, it would still vent the pressure out the curled up edges
Never saw them before, great info.
SAFETY FIRST
AS usual, off topic
Jim
Old 01-12-2016, 12:25 PM   #17
hemi43
hemi43's Avatar
Here's mine installed. I only glued a small portion of it so that I could remove them if they don't work out. They are made of hard rubber, and I think they will interfere with the door. I'll know better once I get the doors painted and installed. The ones posted in LS1's post look like they are a softer material and would work better.
Too bad the ear plugs I have here are bright orange !! LOL
Old 01-12-2016, 02:24 PM   #18
cleszkie
cleszkie's Avatar
I have attempted to use the hard rubber plugs as well. Glued them in and they just get squeezed out over and over. I really like the idea of using an ear plug! Color it black with a sharpie and bingo. It should be soft enough to compress when the door closes without wanting to launch itself. The back side of those orange ear plugs also have a nice finished surface that would look perfect.
cleszkie is offline   Reply With Quote
