Old 02-15-2014, 09:36 PM   #1
'68 Newtricks
'68 Newtricks's Avatar
Upper A arm stud difference?
My 1968 C20 has 9/16" studs while my short bed C10 has 1/2" studs. My CPP arms are set up for 9/16" studs. What the hell is going on? There is nothing in the instructions and no hardware included.
'68 Newtricks is offline   Reply With Quote
Old 02-15-2014, 10:14 PM   #2
'68 Newtricks
Re: Upper A arm stud difference?
Ah crap
The direction don't mention a year split. 63-70 and 71-72
Had to look on their website to see that
Are the crossmembers interchangeable? Or can I press out the studs and put them in my frame. I kind of like the idea of using 9/16" studs instead if the smaller 1/2" ones. Or am I being anal?
Old 02-15-2014, 11:35 PM   #3
seamus2154
I have a 72 c10 and just had to buy and press in a new stud as when i took it apart that stud spun and stripped the splines. I was happy it didn't make the hole bigger, new splined bolt and done. That is a hardened strong bolt I don't see why you would need it larger unless your building a 4x4 off road monster.?? Maybe use a sleeve over your bolt as a spacer inside the arm hole??
seamus2154 is offline   Reply With Quote
Old 02-17-2014, 09:20 PM   #4
'68 Newtricks
Ahhh s***
Talked to the CPP guy and he has no idea what I have. He said the year difference is in ball joint design only, not stud size. Says they only have one size cross shaft. Does this sound right guys? I don't know what to do now. I sent him the pictures you all see. I already have the rear end done (C-notch, crossmembers, trailing arms) so it's not some frame from another style of truck.
Ugg this sucks.
Seamus: what size were those studs?
Old 02-17-2014, 09:58 PM   #5
seamus2154
Looks like the smaller one. I ordered the replacement from the diagram in the LMC catalog and they did offer two that I remember???
Just looked, LMC page 150 part- 8 Pt#30-0269 states 2wheel dr 1/2T 67-72
Old 02-17-2014, 11:34 PM   #6
'68 Newtricks
Interesting
The larger stud is on my C20. The smaller one is on this short bed frame, so I'm guessing C10.
Yeah, I don't even see a 3/4 ton option on LMC. Why would CPP only make their arms to fit the larger stud? I dunno. When I go down to CPP to exchange some other stuff I bought I'll take a look at their other arms etc. I don't like the idea of running a sleeve but I might have to. I'm also missing one dished spacer
Old 02-18-2014, 01:54 PM   #7
'68 Newtricks
Bump
Can a couple members measure these studs on their truck please. Kinda freaking out now
Old 02-18-2014, 02:08 PM   #8
Lee H
Lee H's Avatar
My 72 C10 has 1/2 studs and I'm running CPP tubular control arms.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-18-2014, 02:32 PM   #9
67c10rustbuket
67c10rustbuket's Avatar
mine are .5000000" studs. all C10 should be too.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-18-2014, 03:15 PM   #10
'68 Newtricks
Thanks guys
I guess that's one if the differences between C10 and C20? Dammit, I got to take this up with CPP again. Luckily I don't need to ship stuff
Old 02-20-2014, 02:21 AM   #11
'68 Newtricks
Ok, well CPP says it's loose to help with caster adjustments. I don't like it. I'm having a buddy make up some bronze bushings for it. It wont be tight, but at least it wont be "$2 whore loose".
While looking over the stuff I need to reuse, I'm short one spacer. It's #10 on LMC site. The problem though, they only list the 3/4 ton spacer, which is way different. I need a bare minimum of one more, but would love 4 new ones. Anyone have another outlet for these?
Mine looks like a thick washer, one side flat and the other dished.
Old 01-09-2016, 12:37 AM   #12
Daryl87
Daryl87's Avatar
I'm trying to find two of the concave washers myself. Bodyman took the front end apart and lost the parts for one side! Did you have any luck tracking some down? There is a great picture of them from the forums here:
http://67-72chevytrucks.com/vboard/s...d.php?t=530641
I read somewhere that apparently LMC part #10 from this diagram is a spacer for 3/4 tons.
Based on the diagram I ordered #13 and #14 but they are indeed a flat washer and nut, not the dished washer I'm looking for.
I've tried wrecking yards but so far no luck. Other than tracking down a donor parts truck I may have to go to a machine shop to get two fabricated.
Daryl87 is offline   Reply With Quote
Old 01-13-2016, 10:55 AM   #13
'68 Newtricks
I found some at my local junkyard. I'm guessing they were off a different year truck cause the shape was a little different. BUT, they worked just the same, no problems between the two shapes.
'68 C10 SWB
'85 K30 Blazer
