Old 01-30-2016, 09:07 PM   #1
67 project
Remove rear coils on 67 gmc
have removed the top bolt and cup (bolt snapped) but can get the bottom one off. PO had stripped the bolt head under the trailing arms. Any tips on how to remove the bottom cup and bolt?
67 project is offline   Reply With Quote
Old 01-30-2016, 09:21 PM   #2
firedemon
Re: Remove rear coils on 67 gmc
torch cut the head off the bolt on the spring side so not to damage trailing arm cheaper to replace the cup that holds the spring
firedemon is offline   Reply With Quote
Old 01-30-2016, 09:27 PM   #3
67 project
bottom cup has nut (4 sided) in bottom, just torch off and it should fall out?
Old 01-30-2016, 09:42 PM   #4
firedemon
ya torch the nut off and the spring should come out might have to hammer out the bolt they usually rust in the arm good
Old 01-30-2016, 10:20 PM   #5
67 project
Thanks for your help
Old 01-30-2016, 11:09 PM   #6
firedemon
your welcome
