Old 02-02-2016, 01:45 PM   #1
FlameOut
Steering stabilizer
Did all of the K models come with steering stabilizers? I have a 72 K10 and don't have a stabilizer, and I dont see a place to mount one. Searching for 72 K10 though, I see places selling them
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 02-02-2016, 09:41 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Steering stabilizer
No idea how many were equipped with one. I can only say for sure "not all". My '72 K20 did not have one. Years ago I installed an aftermarket stabilizer. Can't recall for sure why I removed it but it was off for several years, then a couple years ago I re-installed it. Drives pretty much the same with or without.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-02-2016, 10:02 PM   #3
FlameOut
Cool, thanks for that info. I really had no idea what the deal was with them.
1967 Chevelle SS
Old 02-03-2016, 03:05 AM   #4
andrewmp6
Unless you have huge tires they are not needed,And really they can mask steering problems sometimes.
Old 02-03-2016, 05:44 PM   #5
El Dorado Jim
a '73 K10 I had years ago came stock with one, when it went bad my truck shimmied real bad, replaced it and everything was fine, if your truck drives fine, you probably don't need one
El Dorado Jim is offline   Reply With Quote
Old 02-03-2016, 07:00 PM   #6
FlameOut
Unfortunately, I have never driven my truck yet. When I finally got it home over a year ago, I immediately started dismantling. Now that it's about 90% done, I'm hopeful I'll be driving it by spring. I was planning on bigger tires though, 33 x 12.5 x 15, so maybe I better look into adding a stabilizer or aren't those really considered large?
1967 Chevelle SS
Old 02-03-2016, 07:16 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I wouldn't be concerned -- run a stabilizer if you want, or skip it. It shouldn't matter. I'm running 8-ply rated (load range D) 33/12.50-16.5s on 9.5" wide wheels. Like I posted above, it doesn't seem to make a difference.
- Mike -
RIP El Jay
Old 02-04-2016, 12:10 AM   #8
BigRed76
BigRed76's Avatar
Mine GMC came equipped with one. When I bought the truck the existing stabilizer was worn out so I replaced it, made no difference at all. The truck is stock height suspension with 33" tires, for what it's worth.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-04-2016, 09:45 AM   #9
FlameOut
Good info. I'll just drive it for a while and see if I even need it. Thanks
1967 Chevelle SS
Old 02-21-2016, 01:09 AM   #10
mike16
I agree with those above. if you dont need one they serve no purpose.if you need one then its really masking some other problem.
my 68 k20 did not get one
mike16 is offline   Reply With Quote
Old 02-25-2016, 10:18 AM   #11
Prerunner1982
Prerunner1982's Avatar
Originally Posted by El Dorado Jim View Post
a '73 K10 I had years ago came stock with one, when it went bad my truck shimmied real bad, replaced it and everything was fine...
It is just covering up a greater issue. You have a worn out part in your steering/suspension. It's ok as a temporary band aid, but it's not the solution.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
