10-01-2012, 08:12 PM | #1 |
Granny smith, 71 2wd build
Well I thought maybe if I put a build thread up I might get my ass in gear.
Its a medium olive stripper model 71. Here is a pic the day I brought her home in june of this year. |
10-01-2012, 08:19 PM | #2 |
Re: Granny smith, 71 2wd build
Here is the donor 72 I picked up a month later, I was going to just swap the tubs, but the 71 is not "as bad" as I first thought. Im just going to cut up the 72 and use the exterior panels.
10-01-2012, 08:28 PM | #3 |
Over the past month I have fixed the wiring from the PO's. Its running and charging good now, but I think the cam might have a few wiped lobes. One of the PO's swaped the six/3OT combo for a 8/turbo 350. One thing I noticed after looking at a few C10's is during the swap they put the engine in the rearmost position, which I like, there is still clearance behind the hei. Last week I picked up a new truck floor from a local supplier. Last night I started cutting out the "good" side of the floor.
10-01-2012, 08:45 PM | #4 |
67-72 parts collector,…
I like your 2wd very much.
10-02-2012, 09:00 AM | #5 |
10-09-2012, 10:23 AM | #6 |
So, whats up with the build....curious to see how things are coming along. Any deconstruction pics.
10-20-2012, 10:03 PM | #7 |
I actually got some things done the past few weekends.
Got some of the floor cut out. Got the auto column put in out of the donor, put a new masterpower unit in. |
10-20-2012, 10:05 PM | #8 |
If this was a 100point restoration, would I have to recreate the factory paint runs? ha
12-23-2012, 08:38 PM | #9 |
Well.....Get your ass in gear man!! I wanna see you save this rare beast!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
12-23-2012, 09:11 PM | #10 |
I sure wouldn't! I always hate when someone says, that they want it perfect, like it was when it was new. My response is usually something along the lines of, "you must not be very fussy are you?!" LOL!!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
12-23-2012, 09:15 PM | #11 |
Hey Tony, is it getting "chilly" up there in the great white north?!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 Last edited by turp mcspray; 12-23-2012 at 09:15 PM. Reason: double post |
12-24-2012, 12:01 PM | #12 |
Looks kinda like one I've seen from the Fulton area
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
12-25-2012, 08:07 PM | #13 |
Have not gotten very far, but it is coming along. I will not have it bagged, but I will be driving it by spring.
12-27-2012, 12:15 AM | #14 |
....wow.
12-27-2012, 01:11 AM | #15 |
Nice! Make sure the outside leading edges of the toe area, right where the pan meets up to the factory seam, is straight with the rest of the pan. When i installed the prototype on their truck i had to fool with that area. It was an area about 6-8" long....maybe they fixed it once it went into production, told them to
You wont believe how much time that piece will save you, compared to the old patch panels
12-27-2012, 09:51 PM | #16 | |
12-27-2012, 10:09 PM | #17 |
Sure, up in post #13, your pic has three little white dots. Upper left side of pic. Dont know how to circle... Lmk, if you dont understand the location im referring too
12-27-2012, 11:40 PM | #18 |
Understand, the panel I have does not look to bad in that area, but wont know until I get it in there, kinda bummed the seat mounting holes where in the wrong spot, killed my momentum yesterday.
12-27-2012, 11:47 PM | #19 | |
Yeah but, look at it this way....you have a rust free floor going back in. Alot of people would like tohave that floorboard
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-27-2012 at 11:52 PM. |
12-28-2012, 12:02 AM | #20 |
Yep, I think complete floor was the way to go, pretty sure the factory was 18 ga. the triplus parts are 1.2mm. The triplus rocker boxes I bought are super thick. Im just going to drill the spot welds on the seat mount plates and move them over to the blazer locations. I would have thought for sure gm would have made bench and buckets use the same outer holes, but I guess not.
12-28-2012, 12:12 AM | #21 | |
12-31-2012, 03:14 PM | #22 |
WOW going to be a good build!
01-16-2013, 10:06 PM | #23 |
Over new years I got the floor all prepped and put in. What a PITA, took forever to get the seat bracing cut out and positioned in the new pan. I cut/formed the rear of the pan almost exactly like the old floor was.
01-16-2013, 10:12 PM | #24 |
Managing the whole floor in one piece by myself was a chore, but its done.
Got a little discouraged, my dad sent a CL link to a nice looking 72 white 2wd in SC. His asking price was less than what I have wrapped up in this one. I called the day after the ad was posted and it was gone. |
01-17-2013, 01:17 AM | #25 |
How did you make the back bend on the floorboard, and what tools did you use
Looks great...enjoying your progress, thanks for sharing
