Old 02-22-2016, 04:31 AM   #1
Vandals909
4l80 and headers?
Anyone from personal experience have any issues with headers hitting the 4l80?
Not sure if Doug Thorley headers either 1 3/4 hit the trans?
Could I get away with running TBSS or LS3 Camara style headers?
I was told some have to trim an ear off the 4l80 mount to clear the headers?
Vandals909 is offline   Reply With Quote
Old 02-22-2016, 09:04 AM   #2
ssmonte18
Re: 4l80 and headers?
Hooker now makes headers for C10 trucks with LS swaps. I have a set (with a 4L60E) and they fit great. I believe they built their product line around a 4L80E though.
ssmonte18 is offline   Reply With Quote
Old 02-22-2016, 10:31 AM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
First thing I do when I come into possession of a 4L80E is fire up the sawzall and get rid of those damn ears/tabs off the bellhousing. They are ALWAYS in my way. lol
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-22-2016, 11:12 AM   #4
Willie Makeit
Willie Makeit's Avatar
I have a 4L80e with the Doug Thorley's in a '67. Its a very very close fit, but they do clear. Barely.
Willie Makeit is offline   Reply With Quote
Old 02-22-2016, 11:14 AM   #5
Vandals909
Willie. What size headers do you have?
Old 02-24-2016, 10:17 AM   #6
Willie Makeit
Sorry for the delay in my reply. I'm using the 1 5/8" primary tube model. 167-THY-324Y-C
Old 02-22-2016, 11:48 AM   #7
Shon
they fit, cut the ears as mentioned though.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 02-22-2016, 02:41 PM   #8
tony2tall
I just put the 1 7/8 doug thorley headers on with a 4l80e. They clear fine, but I just found out that a column shift with the hard linkage is a no go. The header exits right in front of the bracket mounted to the trans. I'm switching over to a floor shift, but I think a cable linkage would also work if you wanted a column shift.
tony2tall is offline   Reply With Quote
Old 02-22-2016, 03:08 PM   #9
ssmonte18
Old 02-22-2016, 03:12 PM   #10
ssmonte18
http://ls1tech.com/forums/conversion...m-preview.html
Old 02-22-2016, 04:48 PM   #11
Robznob11
Robznob11's Avatar
Originally Posted by ssmonte18 View Post
Curious??? Where did you get the trans x member? Mine looks like that but I made it....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 02-23-2016, 09:22 AM   #12
ssmonte18
Part of the kit from Holley. I think I paid $220. Bolted right in, no hassle.
Old 02-22-2016, 03:27 PM   #13
Shon
Column shift works with Lokar rod unit. Its what I used to have, although you have to put all the 'stuff' on the trans before headers b/c there is no room once headers are in place.
Old 02-22-2016, 05:27 PM   #14
Vandals909
The parts list just keeps growing. So this is the part I will need if I run DT headers
http://www.speedwaymotors.com/Lokar-...FQ-oaQod3ysHIA
Old 02-22-2016, 05:46 PM   #15
tony2tall
I just tried the rod linkage from cpp and there is not enough clearance with the dt header. I don't think there is really any difference between that and the Lokar one.
Old 02-22-2016, 05:48 PM   #16
foamypirate
foamypirate's Avatar
Lokar says you can bend the rod to clear schtuff. Not sure if the CPP kit is the same.
foamypirate is offline   Reply With Quote
Old 02-23-2016, 09:46 AM   #17
Shon
Which DT headers are those? They are not the Long Tube headers by DT for these trucks. Granted its TIGHT but the LT headers exit right at the shifter hook up....these look like shorty headers....
Old 02-24-2016, 10:10 AM   #18
Shon
re-looking at that pic, its exactly like mine was, ie the rod but I had mine installed differently, I hade mine reversed, ie the set screw piece was at the trans and again, I had to install all the trans side of the rod stuff before the headers. I remember that being a PITA b/c I had the headers all on and thought I would not have to move them but there was no way to get the trans stuff set up. And Again, I could only pull the shifter down to 3rd without interfering with header and not allow it to go any further.
Even the cable style will have to be attached to the trans before header is in place, there just is no room with the exit location of the header.
Old 02-22-2016, 05:44 PM   #19
Vandals909
And these are the "ears" you guys are talking About? They are cut off in the photos.
No structural integrity lost by cutting them off right?
http://www.tbssowners.com/forums/4l8...fications.html
Old 02-22-2016, 06:16 PM   #20
Vandals909
Tony are those headers the 1 5/8 or the 1 7/8? I believe they exit at a different angle
Old 02-22-2016, 06:31 PM   #21
tony2tall
Yes the cpp bends but that's not the issue. Its the bracket that comes off the trans. I have
The 1 7/8 headers
Old 02-23-2016, 09:48 AM   #22
Shon
I will also add, my 80e/Lokar Rod/1 5/8" DT LT headers; I could only pull the column shifter down to 3rd, but I had the first run of DT LT headers, I think they redesigned them so you could actually use the stock rod and others I have talked to could get trans to 1st with new header design.
Old 02-23-2016, 10:37 AM   #23
Vandals909
Would be nice if someone from DOUG Thorley chimed in before I spend the money on something designed to fit that it is not clear if it will have figment issues with my 4l80e shifter
Old 02-23-2016, 11:12 AM   #24
Shon
I would first search to see if ANYONE has a set, when I was a dealer they were made in batches that were far and few between and got harder and harder to get, I could buy the whole batch and still wait months....so it might be a mute issue....
But your original question was will the DT hit the trans-the answer is no they fit.
Old 02-23-2016, 12:51 PM   #25
tony2tall
To clarify for me: 71 c10 2wd
2005 6.0 w 4l80e 2wd
Cpp sheet metal stands and slider mounts
Doug thorley tri-y headers clear the trans but the cpp rod shift linkage mechanism connection at the trans sits right where the header exits. Maybe some creative exhaust work could make it work, but I'm switching over to a floor shifter.
Hope this helps!
