Old 02-29-2016, 02:05 PM   #1
70chevytruck
best/cheapest 4 barrel intake 283
I have a 283 with a 1 barrel.....anone know of a decent replacement that doesn't break the bank and has the hole for oil filler?
Also need a stock style aircleaner for a 4 barrel too....thanks,
70chevytruck
70chevytruck is offline   Reply With Quote
Old 02-29-2016, 02:50 PM   #2
kcsa75
kcsa75's Avatar
Re: best/cheapest 4 barrel intake 283
I would check Craigslist or salvage yards. If you can be patient, you should be able to get a stock intake or even a used Edelbrock or Holley for not a lot of money. I bought a used Edelbrock from a guy off CL for $35.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 02-29-2016, 03:02 PM   #3
davepl
davepl's Avatar
Here's a thought, however.
The difference in power between a 2bbl and a 4bbl on a base 350 is 5 horsepower. They're rated at 250 with the 2bbl and 255 2ith the Q-jet.
On the bigger 396 2bbl engines its tapped out at 265hp.
So, if your engine isn't making more than 265hp, the 2-bbl is already plenty!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-29-2016, 06:55 PM   #4
70chevytruck
Except mine is a (1) Barrel....really lame.
70chevytruck
Old 02-29-2016, 07:06 PM   #5
GRX
GRX's Avatar
Here's another thought ... the camshaft is likely for a 1 barrel. Therefore the engine will not make use of larger carb and 4-bbl intake.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 02-29-2016, 08:19 PM   #6
Shady Rascal
Shady Rascal's Avatar
Please show pictures of the one barrel carb on your 283 small block.
( Just because it has one round hole on top doesn't make it a 1 barrel. I'd bet dollars to donuts that you have a two barrel Rochester )
Shady Rascal is offline   Reply With Quote
Old 02-29-2016, 08:30 PM   #7
BluTrukker
BOHICA
BluTrukker's Avatar
no matter what you have. Summit has good cheap intakes under their brand. I got free edelbrock 1406 and put it on a summit intake and it woke up my 307. Of course the factory two barrel was in terrible shape though
Posted via Mobile Device.
BluTrukker is offline   Reply With Quote
Old 02-29-2016, 09:08 PM   #8
davepl
davepl's Avatar
Best running, most reliable, coldest-starting pre-fuel-injection vehicles I have ever owned where the Rochester (2GV?) 2-bbl carbs.
The -best- cold-start vehicle I've seen to date was a tie, but one of them was a 307 '68 GMC with a manual choke. The compression was low so maybe they crank faster in the cold too, but it always lit off in -40F.
My '75 Monte 2bbl cold-started, not plugged in, at -44F, the coldest I've seen (wind chill doesn't affect metal once its ambient). The only reason I plugged it in was that the oil is like lard and its hard on them in that temperature!
Do I sound oddly fond of 2 barrels for a guy that no longer owns any?
Old 02-29-2016, 09:19 PM   #9
Jonlopes
Totally agree, The rochester 2bbl carbs are some of the best running and easiest to tune carbs around. I have never heard of a 1 barrel carb on a v8.
If you are looking for more performance I would look for a good used 350 with a 4bbl intake/ cam already installed.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 02-29-2016, 09:23 PM   #10
Just buy a used factory 4bbl intake. The 4bbl gets better mileage than the 2bbl on a small block, unless you run with secondaries open all the time. Consider the primary CFM compared to the full-time CFM of the 2bbl. Don't get too much carb for the motor and it will give the best mileage and power...when you need it
Old 02-29-2016, 09:48 PM   #11
agawam
there are small base rochesters and large base rochesters, the small base is around 290cfm, the large base comes in 353cfm 380cfm 425cfm and 435cfm, so if you get a large base intake that 283 should really wake up, a Canadian truck 2bbl intake flows the best, it was used on street stock nascars for years
agawam is offline   Reply With Quote
Old 03-01-2016, 02:09 AM   #12
El Dorado Jim
I agree,find a stock 4 bbl intake and I doubt that you have a 1 barrel, I have only had and have ever seen 2 barrels on 283's I have owned several over the years.....try a swapmeet or craigslist for a stock 4 barrel, I see them quite often at swap meets.....are you looking for a stock rochester carb also? pre spreadbore
El Dorado Jim is offline   Reply With Quote
Old 03-02-2016, 12:35 AM   #13
BCOWANWHEELS
keep it stock..........................
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-02-2016, 02:15 PM   #14
frankslagoon
GM did use 1 barrels on the early SB in the bigger trks. they were like 165 hp but had a lot of low end torque. There are acouple over at the yard across the street. the small 2 bbl is about 20 hp more. the moter in my 63 is a 66 chevelle 2 bbl. rated at 195 hp. that's got the small 2bll. on it. I'm alittle shy on fuel around 4500 in high gear. If I was lookin for a little more I think I would go to the 1 1/2 inch flange 1 11/16 bore 2 bll. which flows around 425 cfm. up from the 300 I'm getten now. or probably the quadjet.
frankslagoon is offline   Reply With Quote
Old 03-02-2016, 04:40 PM   #15
GRX
GRX's Avatar
Certain Chevy cars also came so equipped. The 1-bbl 283 set up was very common in Checker Cabs too.
Old 03-02-2016, 05:10 PM   #16
67 chevelle
67 chevelle's Avatar
2barrels
then you have square flange "4 jets" I think 500 cfm
and spredbore "quadrajets" around 750 cfm
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-02-2016, 09:35 PM   #17
hotrodder
I have a stock 283 4 barrel with the oil filler tube and the tab for the spring. It is in nice condition. $75.00, but the shipping would probably be a lot from here in Indiana
hotrodder is offline   Reply With Quote
