Old 06-10-2019, 11:21 AM   #1
69runner
'77 3/4 ton/ 1/2 ton parts interchange ??
New to the board so hopefully asking in the right place ...
I have a '77 3/4 ton long box chassis for use on a project. It has all the HD parts - 8-bolt wheels, duallie rear, etc.. I'd like to convert it to 5-bolt wheels. The rear end is a simple axle swap but what about the front end - can I just swap the rotors? Or what else needs to be swapped - rotors, caliper brackets, calipers, spindles ????
Thanks.
69runner is offline   Reply With Quote
Old 06-10-2019, 11:54 AM   #2
Re: '77 3/4 ton/ 1/2 ton parts interchange ??
A-Arms, and pretty much all front end components are different. Probably th4e easiest way is to take the entire front cross member, unbolt from the 1/2 ton and put it in place of the 3/4 ton one.
