Old 03-08-2016, 07:01 PM   #1
Fla Grown
Fla Grown's Avatar
Will not go into gear
I have a 3 speed Saginaw in my 66 and I tried to put in gear this morning and it just grinds with the clutch in. It was fine when I pulled it in the garage last night. I checked all the linkage and everything looks good and springs are intact. Any thoughts?
Fla Grown is offline   Reply With Quote
Old 03-08-2016, 08:18 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Will not go into gear
Does it go into any gear (1st, 2nd, 3rd, rev) while not moving?
Remove the dust/inspection cover under the tranny and have someone step on the clutch while you observe if you notice anything not moving right.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-09-2016, 09:06 AM   #3
Bigdav160
Bigdav160's Avatar
What happens when you place the trans in gear (clutch pedal depressed) and then start it?
On my blue corvette, occasionally, the clutch disc sticks to the flywheel.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-09-2016, 11:41 AM   #4
Fla Grown
Fla Grown's Avatar
First I have to get it out of the garage.
It will go into all gears if the engine is off but if running it grinds.
When I get home today I will push it out and try to start it with the clutch in and in gear. Coil wire removed so I don't crash into anything! lol
I have a feeling the pressure plate teeth are shot. I have had a shutter when taking off since I got the truck 5 years ago even though I had the flywheel resurfaced.
Possibly new clutch, pressure plate, and flywheel?
Old 03-09-2016, 12:21 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Yeah, it sounds like the clutch is not releasing. You won't be able to start it with coil cable removed and probably don't need to push it anyway. You probably have figured you'll have to remove the transmission and dig into it but you should be able to see what's happening from underneath with the dust/inspection cover removed. (not while running of course -- )
06 Trailblazer
Old 03-09-2016, 02:32 PM   #6
Fla Grown
Fla Grown's Avatar
So I got it out of the garage, put in in 1st and started it up. It will move if I give it gas but acts like the clutch is slipping and it wont shift out of that gear with the pedal depressed.
Old 03-09-2016, 02:37 PM   #7
A1971Blazer
A1971Blazer's Avatar
when it's hard to shift or grinds.......clutch is shot..........
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-09-2016, 02:47 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Good indication the clutch or pressure plate are gone. As you mentioned above the best thing to do is to go with a good brand clutch, pressure plate and throwout bearing -and possibly the flywheel if it looks burned or has stress fractures from over heating.
Make sure you get the right throwout bearing since there different types. Keep the old one until you get the replacement to make sure it's the same size.
06 Trailblazer
Old 03-10-2016, 09:28 AM   #9
Fla Grown
Fla Grown's Avatar
Thanks for the input! Towed it to the shop yesterday. Unfortunately I am to busy with work to break it down so I will have to pay for this one.
