Old 03-14-2016, 02:07 PM   #1
gmclowsierra
front bumper question
I have a 78 suburban. will the front bumper off of an 81-87 truck fit? thanks
gmclowsierra is offline   Reply With Quote
Old 03-14-2016, 04:53 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: front bumper question
Yes and No. The front frame horns are different, but you can get the 4 brackets for the front bumper for the 81-87 and make it work. The front horns may need to be cut off to make it work.
Hope this helps, I can get some pics once I get back to my shop later...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-14-2016, 08:26 PM   #3
Front Range
Front Range's Avatar
Over time the top edge of the later year bumper dug into my early year fenders. There is a small gap that looks ok - until the body flexes. I never modified the bumper tips though.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 03-16-2016, 09:34 AM   #4
aggie91
aggie91's Avatar
Here are the pictures.
81-87 Front Frame Horn:
81-87 Front Bumper Brackets:
73-80 Front Frame Horn:
The oblong hole in the side of the frame rail in front of the core support mount is in the same location on both year models. Remove the bracket on top of the 73-80 front frame horn. Use the oblong hole to line up the frame bracket for the later model front bumper.
The outer brackets bolt to holes behind the core support mounts. I am not sure if they are in the same locations, but should be easy to drill if needed.
Karl
The LST Challenge:
