Old 03-10-2016, 12:25 PM   #1
7tee
7tee's Avatar
Sway Bar Installation Help...
I will be getting my 1 1/4" front sway bar in a few days for my '70 and my question is, does the front end stay on the ground when they are installed? Thanks Ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 03-10-2016, 01:14 PM   #2
fastpace
Re: Sway Bar Installation Help...
When installing you should have the suspension loaded. If there is enough room you can jack it up with the sway bar end links attached to the a-arms, lower the truck back down, crawl under and lift the sway bar up and mark and drill for the center bushings, bolt up the bushings then tighten up the end links.
The easier option is pulling it onto a set of ramps or something secure for the tires to rest on with some height.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 03-10-2016, 01:22 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
No drilling required. The holes for the frame mounts are there.
*IF* you want to mount the bar directly to the frame (if you have a lowered truck), then you can drill the holes, or buy an ECE "lowered mount" and use all the stock holes.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-10-2016, 07:08 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
On trucks that came form the factory with a front sway bar. Is the sway bar completely bolted on or is some of it riveted in place. I ask because on my previous truck it didn't have the factory sway bar and when I added it I believe I had to drill out a couple of rivets where the rear of the sway bar bolted up.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-10-2016, 07:48 PM   #5
swamp rat
swamp rat's Avatar
Bolted, been covered a lot, try doing a search for front swaybar install ect.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-10-2016, 07:59 PM   #6
Already Gone
I had looked and never found the answer to my question. There are lots of sway bar install threads but never seen my question asked, answered or explained. Thanks for the info.
Old 03-10-2016, 09:27 PM   #7
FL71C10
This is a really good thread
http://67-72chevytrucks.com/vboard/s...light=sway+bar
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 03-11-2016, 08:28 AM   #8
7tee
7tee's Avatar
"Loaded" is the answer to the question I was looking for. I couldn't find this in the search for help threads, thanks fastpace...ed...
2010 Acura RL...
Old 03-11-2016, 12:48 PM   #9
67ChevyRedneck
Factory installed bar mounts (on the frame) were riveted in place and the rear rivet is shared between the bracket, frame, and a cross member.
When you install brackets on a non factory sway bar truck, you have to remove the rivet from the cross member to install the rear bracket mount, then a bolt holds the cross member, frame, bracket in place.
Jesse James
Project "On a Dime"
Old 03-11-2016, 01:17 PM   #10
7tee
7tee's Avatar
Thanks 67, will do...
2010 Acura RL...
Old 03-11-2016, 06:15 PM   #11
Myoldtruck
Myoldtruck's Avatar
You didnt say if this is a stock gm bar or a aftermarket bar. I just installed a performanceonline front sway bar, had the truck prepped for the new bar, I drilled out the rivets, had the new stock mounting brackets installed. Guess what, aftermarket bar I got didnt use any of the oem mounts or holes. I installed with truck suspension under load. I did have to turn the tie rod outer adjustment clamps 90degrees so their bolts didnt hit the sway bar.
I did notice a good improvement in handling right away.
Myoldtruck is offline   Reply With Quote
Old 03-16-2016, 07:44 AM   #12
7tee
7tee's Avatar
Update;
Received and installed my front ECE sway bar. As mentioned above, being that there was not a factory sway bar installed, I did have to grind down two rivet heads and knock the rest of it out with a punch. Installation was pretty much straight forward and the handling difference is amazing. Thanks to all for your input...ed...
2010 Acura RL...
