Old 03-22-2016, 10:57 AM   #1
72K5er
4" lift with 35's question.
I'm switching some stuff up on my 72' K5. I've got a 4" lift now and I want to run 35's(315/75/16), I just sold my 255/85/16's. I have stock steering set up with 16x8 steel rims with 4" of backspacing. Anybody running a set up similar to this? Any rubbing issues? My rig is pretty much all road, no real heavy offroad. I was lookin at the pitman arm and it looks close to where the tires would be. Can the factory axles handle 35's with no problem, just curious about the bearings. Any help is appreciated. Thanks
72K5er is offline   Reply With Quote
Old 03-22-2016, 09:42 PM   #2
swamp rat
swamp rat's Avatar
Re: 4" lift with 35's question.
This subject has been covered many times, i don't want to be the guy that tells you there won't be a problem and be wrong, but do a search using Key word "4" lift 35"" tires and see what you come up with. After typing in the key words try using "Posts" or "Threads" towards the bottom of the search page. Link below.
http://67-72chevytrucks.com/vboard/search.php
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-23-2016, 09:33 PM   #3
70stroker
70stroker's Avatar
That's the set up I have except 35x12.50/15. Check out my build
70stroker is offline   Reply With Quote
