Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-10-2016, 11:20 AM   #1
'65Burb
rear brake lines
My brakes are a mess. The 3/16" brake lines on the rear axle were so bad that when I tried to loosen them to replace the wheel cylinders, one "pretzel twisted". So, I will be replacing them, obviously.
But here is my question. I am betting that the original steel brake line to the rear was 1/4". Can someone confirm that? If I am right, then the rear flexible brake hose went from the 1/4" line to the "T" fitting reduction to 3/16" lines on the axle. Therefore, if I order an original rear brake hose, it would have the correct fittings to accomplish this, right?
Someone replaced the original rear steel brake line on mine. I can tell because they are the sections of 3/16" steel line like you find at the parts store joined by fittings.
Thanks in advance, Lou
'65Burb is offline   Reply With Quote
