Help just found these in the rear end..
What the hell is this?? They were under the pinion down in the pocket. My pinion was making noise so I pulled it apart to rebuild it and the pinion was loose up and down. Went to set the pinion depth and it was 1/2 inch loose in and out just like it was when I pulled it apart and thats when I found these shims of some sort. Two of them are a little crunched.. Anyone know what they are or maybe my 12 bolt is some early one off?? It is a 65
Re: Help just found these in the rear end..
part of the bearing cage maybe ??
If you don't like this ![]() |
![]() Join Date: Mar 2013
Whatever they are they don't seem to be in to good a shape. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
that is interesting.
it's hard to tell how big they are. what are the dimensions?
53 Chevy Pickup |
They look like clutch tabs from a posi that broke off. They would have been holding the friction plates in place with the carrier.
I would also say clutch plate parts, was a posi.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
Ah figured it out, its off the end clutch plate cage. Thank you all
I assume theres 2 in there and all the tabs are broken off..
60-66 Nut
That cage would be for the Dana/Spicer posi unit, not the Eaton style posi. Does your 12 bolt currently have a posi carrier in it?
#15 |
#16 |
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#17 |
60-66 Nut
The ears on those plates, keep the clutch discs and plates from beating up the inside of the carrier. Plus they now have a little more room to move around.
#18 |
They sure aren't horseshoes. Any damage to crown and pinion?
#19 |
