Will Big Block be TOO MUCH?
Hey all, i am currently looking at a truck with a BIG BLOCK 454 and a TH400 to back it. The truck looks to be a good deal and is all around what im looking for, BUT im going to be using to for daily driving, and i wonder if that setup is going to be too much. So, for guys that have had big blocks, how is the cab drone and overall noise when your driving around? It always drove me crazy in a DD after a week of fun, when your sitting in traffic and you cant hear yourself think. could i make it decently quiet with the right muffler? (SORRY) Are the vibrations going to be much worse? and as far as fuel, is it going to be much worse than a 350/ th350 setup?
please let me know your opinions, seems like i might have to act fast on this one. Thanks! |
Re: Will Big Block be TOO MUCH?
Um, a big block isn't any louder than other V8 motors. That all depends on your exhaust system. A single outlet system w/ a factory style muffler on a 454 will be quiet in comparison to a 283 running open headers in a hot rod.
And yes, a big block will burn more gas. But the smile on one's face when one floors it should make up for that... |
I may get flamed but I would never even consider a BB for a daily driver. The fuel mileage will be worse than a 350/TH350, probably high single digits. As far as noise, with proper mufflers it wouldn't be an issue. Vibration is not really an issue either. But poor mileage and harder to cool are real issues-especially for a DD. My .02
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#4 | |
![]() ![]() Join Date: Feb 2004
Yea, agree that mileage will be poor especially with a 400 turbo --OD would help---- but unless you pull some weight everyday the extra cubes just burn more gas.
Ask him what mileage he gets. Maybe it has a 3.08 gear in it which would help. What year truck is it 72?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
20' Daredevil (Ret)
![]() Join Date: May 2003
It's been a very long time since I owned anything with a BBC (1969 El Camino SS, 396/375HP, TH400) but the above comments are spot-on. Do you need a big block? No, but gobs of torque = great fun. Yes, fuel mileage suffers a bit, but my 350/350 K20 gets lousy mileage too. As to noise or vibration, no worries as stated above. It's loud if you put loud exhaust on it.
My two cents, if you like the truck and don't mind shelling out a bit more for gas.... buy it and enjoy.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Dec 2013
If your worried about mileage and engine noise buy a Kia
![]() These probably aren't the best dd you could pick you'll be able to quiet it down but to get good mpg you'll have to drop a 6 cylinder in it . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
My truck is a dd. I have a 350 with a th400 trans. I just checked my mileage today and got 11 mpg.. But I have a blast in it and is a conversation piece when I go anywhere,
Brian ![]() |
![]() ![]() Join Date: Feb 2009
Depends on your cam, manifolds and mufflers I'd guess. Speaking for my 402, smooth like a switch watch, and I haven't taking a timing light to it since......since....never mind. As MPG goes, the 350 Vs 402 Chevy blocks got about the same. What, 10-13? That 454 probably gets what, 8 MPG?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#10 | |
![]() Join Date: Jun 2015
There is such a thing as too much?
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
Neither my 1999 (350) Tahoe nor my 2001 (5.3 whatevertheheckitis) Tahoe get much better mileage than my '69 (327) K10, which has achieved 14 MPG Highway.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
![]() Join Date: Jan 2001
Not a truck, but I had two identical GM cars I built. Both were full-sized wagons and were almost identical (consecutive manufacturing years). One got a 455 Olds and the other a Chevy 350. I could reliably get at least 50% better mileage out of the 350. Of course, the Olds was much more fun to drive... that might have had something to do with the mileage as well.
![]() Join Date: Feb 2007
Empty my 489 is getting a solid 12mpg on the highway w/ OD, but in town it gets around 9-10. I have sqweeked out 13mpg before but not with my current 650AVS carb. The truck weighs 6,000lbs. As soon as I put a load on it drops to single digits and when I have 10,000lbs+ behind me it drops to 7mpg but man does it sound awesome getting the job done! Heaviest I've hauled was 19,890lbs total gross through the Rockies.
I've owned less than 10 small blocks in my life, primarily 350's and at various build stages from stock smog era to lightly warmed over to a mini blown 383. The best mileage I have ever gotten with any of them was 14mpg and that was a lot of parts matching and engine tuning. So I am very happy with my big block mileage numbers, the work that it can perform, and the 600+ ft/lbs of torque it builds. Steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#15 |
i daily drive my 750hp small block. doesnt bither me a bit, gets 12 mpg on e85
#16 |
![]() Join Date: Jan 2002
If this is a stock 454 with a well tuned Quadra jet and a 3.08 gear, there should be no reason it won't pull 12 mpg. My 72 gmc with a 67 corvette 427 gets 10 mpg all day long. I used to have a 72 shortbox with 3.73 gears and a 402/400 combo and it got 10-11
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#17 |
![]() Join Date: Jul 2015
not a truck..but still somewhat of a comparison. My brother has a 80 Pontiac grand safari wagon, it has a fully built 496 BB, 950 double pumper, TH400, ford 9inch with 3.90 ish gears, set up to go in a straight line as fast as possible. We rolled up to Ocean City last year for Cruisers (about 170 miles each way) and knocked out 11-12 the whole way up at 65mph. He also had a bunch of luggage stacked on the roof to add to the sleeper look, so it was about as aerodynamic as our trucks.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#18 |
I love to feel the raw torque of a Big Block, and with sensible carb/jetting and OD transmission you can get decent (for a non-fuel injected) mileage if you keep the right foot under control.
Besides, you can't beat the look of that beast under the hood! POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
#19 |
thanks for the input guys, il let you know how it fairs with dding!
#20 |
Go for it! If my 350 didn't run so well, I'd have a 396 or 454 in mine....
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
#21 | |
![]() Join Date: Sep 2015
(and it doesn't look half bad on a stand)
"Orange Crush" |
#22 |
Moderator
![]() Join Date: May 2007
No
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#23 |
![]() Join Date: Nov 2013
I had a 67 swb fleet side with 454/400 combo 3.08s outback and it would run 11 mpg when I treated her nice but when the right foot got heavy my wallet got light. As far as the noise mine was pretty quite again until the right foot got heavy, but boy was it nice to listen to that bbc bark. The cooling thing though you do need a 4 core radiator if your going cruising in stop and go traffic, but I think more of that was caused by the blue anodized miniature fan I was running without a shroud. I liked it well enough I'm building another one now, although it won't be a dd.
#24 |
![]() Join Date: Mar 2016
big block = happiness
#25 |
Noise and vibration - no more an issue than a small block. My '85 1-ton (454/Turbo 400) glides pleasantly down the highway. Before the suspension and drivetrain had the wear on them they do today, the wind through the old, dry weatherstrips made much more noise than the drivetrain did.
There's more room for a 350 to get better fuel economy than a big block, but recently my '85 (with 4.10 gears!) does 11.5 or so, light to moderately loaded, on long trips. At one time I could dependably get 12.25 to 12.5, empty, on the highway. Mixed driving is 10 or a little better, but I rarely lay into it. My '67 Suburban w/350 and 4-speed manual gets no more than 2 MPG better, and it's a stock engine breathing through a little Rochester 4G in a vehicle weighing 700 lbs. less (4,600 vs. 5,300) with a manual trans. A big block insures your truck's limitation is never its engine. ![]()
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
