Old 05-03-2016, 12:32 PM   #1
Blue Ox
1960 to 1972 front axle swap
I know similar topics have been discussed elsewhere around here. Maybe it's just me... but I'm not coming away with a good sense of what the interchangeability (is that a word?) of early and late model front axles is.
I have a 1960 GMC 3/4-ton (K1502) that I'm fixing up. Like a lot of folks, I'd like to upgrade to disc brakes on the front, but I have the closed-knuckle front end and it's looking like going with a later model axle is going to be the most efficient method.
I have a line on a complete front axle from a 1972 K20 (correct gear ratio and everything). Can anyone give me a clear summary of what I can expect to have to modify (if anything) in order to get that to work?
I'm not worried about modifying the brake system to work. I can figure that out. I'm just wondering about the physical compatibility between the two axles (spring perch locations, any offset in the location of the diff housing, etc.).
Thanks!
Blue Ox is offline   Reply With Quote
