Old 05-02-2016, 02:05 PM   #1
BuckLucky
BuckLucky's Avatar
Can I use a block Mount Mini starter to replace my Belhousing mount starter ?
I've searched the forums a bit but didn't come up with an answer . I have a 72 Blazer 350 4x4 with 4speed and was wanting to upgrade my stock Starter to a high torque Mini Starter . Wasn't sure if I could do this with having a bell housing mounted factory starter. Has anyone tried? Block has the mounting holes I'm just not sure if there is any issues with clearance on the bell housing .... Any Help would be appreciated . Thanks
BuckLucky is offline   Reply With Quote
Old 05-02-2016, 04:06 PM   #2
BuckLucky
BuckLucky's Avatar
Re: Can I use a block Mount Mini starter to replace my Belhousing mount starter ?
I found my answer after searching more . Looks like I can use the block mounting holes without interference from the Bell housing .
Old 05-02-2016, 09:01 PM   #3
Mike C
Mike C's Avatar
Yes as you've seen. I have one on my Jimmy. I went with the style that did not support the bendix on both ends as that meant there was nothing that had to go into the bellhousing that might interfere. But I would think either would work.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
