Old 05-06-2016, 09:33 AM   #1
Jpd
1963 or 64?
Hey. New to the forum. I have a truck the titled a 1963 but I could swear it's s 64. It's doesn't have the wrap around windshield or the doors I would expect The only thing I can think is it was built late in 63. I would attach pics but I guess I don't have permission. Any answers?
Also I want to maybe put some rally truck style rim. Would 15x7 be a good fit? What size tires? Thanks in advance for any info. Jeff.
Jpd is offline   Reply With Quote
Old 05-06-2016, 09:36 AM   #2
DakotaKid
Re: 1963 or 64?
64. 63 had kneeknocker windshields. probably an early 64 model that was "titled" in 63. the vin should show a 64 date though. whats the first few digits of the vin?
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 05-06-2016, 09:45 AM   #3
Clyde65
Clyde65's Avatar
Re: 1963 or 64?
Whats the first 6 of the vin??
Ralleys would work either 5 lug or 6 are out there.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-06-2016, 09:55 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 or 64?
That's a 64 to 66. Can you post the vin? I may be able to help decode it.
Old 05-06-2016, 10:04 AM   #5
Jpd
Old 05-06-2016, 10:12 AM   #6
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 or 64?
From what I can read your vin comes out as 1001 P F2300A
Alright, here we go,
1001 makes it a 1000 series with a 115 inch wheel base.
P means it was built in the Pontiac, Michigan Plant.
F makes it a 64-66.
2300 is the Serial number.
A is a GVW of 6000 pounds.
Only way to tell if it's a 66 is by the red lettering in the grill. If it doesn't have that red lettering it's a 64-65.
Does it still have the original V6?
Old 05-06-2016, 10:30 AM   #7
Jpd
Re: 1963 or 64?
Still original v-6. 69k miles. I don't think this truck could be anymore orginal. Orginal shocks and everything. I changed the point for a tune up and they were marked GMC. Have a lot a documentation including the orginal title and loan documents. I want to keep it orginal except disk brakes that the reason for the rims question. Jeff
Old 05-06-2016, 10:32 AM   #8
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 or 64?
The GMC V6's rock man! Don't let Anyone tell you otherwise. There's a guy local with a 305 that has 600,000 on it!
Old 05-06-2016, 10:37 AM   #9
vin63
It's Better With Nitro
vin63's Avatar
Re: 1963 or 64?
...I have a truck the titled a 1963 but I could swear it's s 64.
As the others mentioned, it is a model year 1964, but was most likely originally purchased in 1963, so when it was registered, the current calendar year was used for the documentation at the DMV. I've seen a few registrations that had the same calendar year vs model year discrepancy.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-06-2016, 10:48 AM   #10
Jpd
Re: 1963 or 64?
Anybody still running the V-6 run 10w oil like they recommend in the manual?
Old 05-06-2016, 11:08 AM   #11
vince1
Re: 1963 or 64?
That is a beautiful truck.
If they were calling for 10W use 5-20 or 5-30? Synthetic? With synthetic maybe the seals will leak? I think oils today are far superior to what they were back then.
vince1 is offline   Reply With Quote
Old 05-06-2016, 11:09 AM   #12
Jpd
Re: 1963 or 64?
Old 05-06-2016, 11:12 AM   #13
Jpd
I think I'm gonna go with 5-20. 10w oil has no detergents. I've be looking for the spin on oil filter adapter but they are few and far between. Anybody have one for sale?
Old 05-06-2016, 11:18 AM   #14
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 or 64?
Ask around here:
http://6066gmcclub.com/index.php
I run 15W-40 in my V6. You'll have to locate a 67 or later model V6 from my knowledge and it will have the spin on filter. Mine is a 67 engine and it does.
Old 05-06-2016, 12:41 PM   #15
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 or 64?
The oils today don't have the zinc additive anymore because all these new cars have roller cams or ohc.
Old 05-06-2016, 01:01 PM   #16
Jpd
I was considering that also with the solid lifters.
Old 05-06-2016, 01:06 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 or 64?
I'd run rotella 10w-30 or 15w-40 with a ZDDP zinc additive.
Old 05-06-2016, 04:13 PM   #18
forestb
forestb's Avatar
Re: 1963 or 64?
I had the same thing with my registration. The registration says it is a 63 and it has a 63 grill but a torsion bar front end so I say it is a 62.
forestb is offline   Reply With Quote
