Old 05-21-2016, 10:46 AM   #1
Nodnarb76
Nodnarb76's Avatar
Is 220 degress ok?
Still ironing out the kinks on my LQ4/4L80 swap into my 87 Suburban.
been noticing the temp gauge has been reading around 220-230.
Installed a new 195 degree thermostat before I installed the motor. Going to see if I can program my fan controller to come on a little earlier. Seems to be getting hot when running on the interstate. Don't have any leaks, and I have the sensor for the Dakota Digital gauges mounted in the pass side cylinder head.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 05-21-2016, 11:15 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Is 220 degress ok?
My lq9 has a 160 thermo in it.i pulled it to check and i assume thats what came in it..didnt look like its ever been off engine.and my fans are programmed to come on at 175 for fan #1 and 185 for fan #2..its runs all day around 175-180 .My 2013 truck with 5.3 runs around 220
mongocanfly is online now   Reply With Quote
Old 05-21-2016, 12:24 PM   #3
dec010974
dec010974's Avatar
my .030 LQ9 runs a normal engine temperature 185 degrees. for a while, I thought my E-Fans didn't work. im only a novice at this LSX thing, but the factory thermostat is 180 degrees.
dec010974 is offline   Reply With Quote
Old 05-21-2016, 12:50 PM   #4
dec010974
dec010974's Avatar
I also want to add that GM vehicles, not altered from its factory settings, including my 2016 suburban, normally runs around 220 degrees. I think its called thermal efficiency. Nodnarb76, your LQ4 engine, in its LSX swapped form, runs a little hotter than I would want it to. I would check the temp. gauge, against the OBDII gauge to see if there is an accuracy problem. Other things to consider are the water pump's age, coolant, is it fresh, is it enough, how did you remove all the air pockets, radiator may be clogged, Cylinder heads may be clogged, or something weird may be happening with the steam passages in the cylinder heads. a friend of mine had this same problem. he installed the Temp. gauge wrong. good luck and keep us informed about the outcome.
Old 05-21-2016, 01:52 PM   #5
Nodnarb76
Nodnarb76's Avatar
Thanks for the advice, when I installed the motor installed new water pump, thermostat, radiator, hoses. Went with AC delco 195 degree thermostat and AC delco water pump. My Entropy Radiator has electric fans, I may have them set to come on too late, going to set them to a cooler temp tomorrow when have time. I will keep everyone posted, thanks for the help.
Old 05-21-2016, 02:47 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Is 220 degress ok?
Best to make sure no air is in the system. These motors are really bad about traping air and even worse to get it out. Mine runs all day @179* and the fans come on @185*. When driving they never do come on.
Temp on should be around 185* and if you have the fans sized right it should never see 220. Most newer GM trucks run 210* at cruising speed at least all three of mine do the ones I bought.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-21-2016, 03:14 PM   #7
mongocanfly
On the lq9 thermostat I replaced mine and water pump when I did the install..oreillys had a 180 and a 160..mine already had the 160 so that's what I went with
Old 05-21-2016, 09:27 PM   #8
ChuckLee
LS based motors love 210 all day, and they make better power when "hot". 230, that is borderline for sure.
ChuckLee is offline   Reply With Quote
Old 05-21-2016, 11:52 PM   #9
storm9c1
*** That's interesting ***
storm9c1's Avatar
You also don't want the electric fans running while on the interstate. They will only impede airflow and the electric motors will draw more current at that speed because they are being overrun by natural airflow. Airflow is already optimal through the radiator at highways speed without the fans. All stock/OEM systems that I know of will turn off electric fans above a certain speed. So you may want to install some LED lights to monitor when your fans are running.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 05-22-2016, 01:45 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The stock stat is 195. Whoever had the 160 stat did not have a stock part. Some guys switch to the 160, but no vehicle was equipped with it o.e.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-23-2016, 08:48 AM   #11
Nodnarb76
Nodnarb76's Avatar
Noticed a small kink in my lower radiator hose, I wonder if the lower radiator hose is collapsing shut under acceleration?
Old 05-23-2016, 07:19 PM   #12
storm9c1
storm9c1's Avatar
Newer hoses are designed not to collapse, but a kink in a radiator hose is not good. I'd fix that for sure.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 05-23-2016, 08:23 PM   #13
Nodnarb76
Nodnarb76's Avatar
That's what I was thinking. The hose has a bend in it that is creating a flattened spot that I'm thinking is collapsing when I'm driving.
Old 05-23-2016, 09:52 PM   #14
ChuckLee
Yikes. That's a blowout waiting to happen (and hopefully u would catch it before you ran it hot and burned the motor up). I would change that pronto. Good eyes.
Old 05-23-2016, 10:59 PM   #15
Nodnarb76
Nodnarb76's Avatar
[QUOTE=ChuckLee;7602997]Yikes. That's a blowout waiting to happen (and hopefully u would catch it before you ran it hot and burned the motor up). I would change that pronto. Good eyes.[/c
Do you suppose this could cause the truck to run hotter when driving at interstate speeds? Or even impede coolant flow at idle enough to make it run hotter than normal?
Already ordered a stainless hose to match my upper hose.
Old 05-23-2016, 11:20 PM   #16
ChuckLee
Restricting flow means high pressure everywhere in the coolant system between the water pump outlet and the restriction. This means high chances of a blowout at the weakest point in the cooling system. Restricting flow also means anything between the restriction and the water pump inlet will be too low, which will increase heat.
Old 05-24-2016, 08:58 AM   #17
zach_carver
zach_carver's Avatar
My 2007 LS2 runs 210-212 degrees all day long. Even sitting in traffic after driving it may get to 215. It has a stock thermostat and everything, seems to run really good.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-24-2016, 09:25 AM   #18
ChuckLee
Yah it's totally safe...and makes better power there than sitting at 175-190 like on most engines.
Old 05-24-2016, 10:57 AM   #19
MalibuSSwagon
Who programmed your ECM? Not sure why people run aftermarket fan controllers when the factory ECM does it better.
MalibuSSwagon is offline   Reply With Quote
Old 05-24-2016, 11:57 PM   #20
clinebarger
Convoluted Radiator Hose RESTRICTS coolant flow, I hate them! Only use them when absolutely necessary!
As Storm9C1 stated, Running Cooling fan/s at greater than 40mph.....WILL cause a airflow restriction that could be attributed to temp rise on the highway.
Aftermarket Electric Fan Shrouds impede airflow as it is, No need to make it worse.
I have fixed many overheating LS converted trucks with a Clutch Fan & Shroud, Similar to what you had originally.
clinebarger is offline   Reply With Quote
Old 05-31-2016, 03:38 PM   #21
Nodnarb76
Nodnarb76's Avatar
Got my lower house replaced with a stainless steel hose, now stays at about 210 degrees, which is the 12:00 mark on the stock gauge. So I think I'm good now.
