Old 05-19-2016, 03:23 PM   #1
61K10
61K10's Avatar
60-61 hood springs
Anybody re-pop a good hood spring? my stock ones on my 61 wouldn't hold up my hood and the new ones won't either. bought them probably 3yrs ago.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-19-2016, 03:37 PM   #2
dieseldude4bt
Re: 60-61 hood springs
Did you put a blanket on the hood?
I had to cut one coil off and heat and re-bend a hook when I did that.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 05-26-2016, 12:50 PM   #3
61K10
61K10's Avatar
Got some new hood springs from brothers, and they are much stronger than my stock ones, and the other after-market ones. I just have the j hook you can by for installing the springs. Gonna need another set of arms, as the new springs are that much stiffer.
1961 chevy K10
Old 06-09-2016, 07:13 PM   #4
61K10
61K10's Avatar
For anybody that's interested, the new springs from Brothers hold my hood up all the way. For how long your guess is as good as mine.
1961 chevy K10
Old 06-10-2016, 12:15 AM   #5
Captainfab
60-66 Nut
Is there a place on the J hook where you could hook a ratchet strap to, and the other end of the strap to a solid object?
Old 06-10-2016, 01:27 PM   #6
61K10
61K10's Avatar
Capt--the problem was i didn't have the hood all the way up. put a strap on the hood to a rafter and pulled it as far as it would go. Springs went right on. Was just that 1/2" made the difference. they are stronger for sure as i could remove the old and put them back on but not the new ones.
1961 chevy K10
