6.0 Swap w/new Enytropy Radiator/Fans running hot when not moving.
Still fixing all the little problems after doing my 6.0/4L80 Swap into my 87 Suburban. Along with the motor installed an Enytropy radiator/fan kit.
Fans come on low speed then high speed like they are supposed to. When I'm driving and have airflow through the radiator, everything is fine, once I come up to a light or stop, temp goes up about 20-30 degrees, even if the fan is on high speed, then goes back down when I start moving. When I installed the motor I replaced the water pump and thermostat with new AC Declo parts. Any ideas?
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
Re: 6.0 Swap w/new Enytropy Radiator/Fans running hot when not moving.
Sounds like air trapped in your system do not for get to turn the heater on to circulate the water through the heater core
#3 | |
Thanks for confirming what I was thinking.
Did you fill the engine from the top radiator hose dis connected from the rad?
I did, I filled through the upper radiator hose until I had coolant coming out of the steam hose, re-connected everything. Because my filler neck is at an angle I even jacked up the pass side of the truck to try and get the filler neck level so it would hold more coolant when I filled the radiator.
are you sure that the fans are blowing in the right direction?
1973 K5, full vert, 6" BDS lift, 35 Mickey T MTs 1984 K10, 8" lift on 35s 2004 3/4 4wd, 33s Toyo Mts, Long Tube headers, 3K multidisk 80e, tons of miles 2011 Yukon XL | Bone stock 2013 Audi Q5 |
Pretty sure they are, they would only plug up one way, when the fans are on high speed, I can put a rag in front of the grille and it will pull it toward the grille.
update: when driving to work today started getting hot when driving on interstate too. then when came to a stop still getting hot. Fans are coming on, no leaks anywhere, when I pulled over overflow tank was bubbling.
Is it possible a new AC delco thermostat is sticking?
If you think there is still trapped air in the system try loosening the temp sensor till you get some coolant to run out. Careful of the hot coolant.
#10 | |
it almost sounds like you have a leak in the system and it's not pressurizing up, or your coolant mixture is off
![]() Join Date: Aug 2014
How hot is it getting? My LS2 runs 210ish on the highway on a good hot day. Sitting still in traffic 212-215ish.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
Just used that spill free funnel thing for burping my system today. Works great. Might be worth a try.
#13 | |
#14 | |
