Old 07-10-2016, 05:46 PM   #1
CG
BlahBlahBlah
Door panel install
So I got a new interior for my 68 K20 from Grumpy Old Man. All I have installed so far are the visor and door panels. I need to have my seat frame sand blasted before I install the cover, and tearing apart the dash to install the new pad is going to be a pain so Im trying to have other stuff ready to do under there before I get to it.
My door panels are backerboard with vinyl covering. Im wondering if anyone has ever used a long wide strip of Velcro to attach the bottom of the door panel vs using the factory screws. I think it would look a bit better without the screws, just not sure if Velcro is strong enough to keep something like a door panel on.
Old 07-10-2016, 06:54 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Door panel install
Try your local fabric store for 2" sticky backed Velcro it will work fine and hold the panels securely without hardware . As simple as peel and stick .easy peasy
Old 07-10-2016, 07:47 PM   #3
tdangle
tdangle's Avatar
Great idea!! I have new panels I bought off of EBay. Basically the same thing hardboard with a cover on it. The factory nuts and holders are rusted in and I have been trying to figure out what the best way to fix them is. The velcro idea is perfect.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-10-2016, 08:51 PM   #4
CG
BlahBlahBlah
The arm rest, metal strip at the top and the handles do a fine job of keeping the rest in place. I just wasn't sure if people found they would catch and pull the panels back at the bottom if they used Velcro. Ill get some and give it a go, if I mess up the panels down the road I know where I can get another pair =)
Old 07-10-2016, 09:08 PM   #5
Grumpy old man
That 2" Velcro has a lot of tooth try just a few 2x2 squares located on the high spots first .
