Old 07-30-2016, 03:19 PM   #1
dtkarst
Think I should do it?
Been thinking about this 66 c30 for awhile now and not sure if I should do it..custom can big window. 327 in it all new brakes, and wrecker flat bed. Has some rust in the floor and needs some wiring stuff taken care of. Thought it would be a cool little rat rod or something what do you guys think? I can get it for 1000
dtkarst is offline   Reply With Quote
Old 07-30-2016, 03:20 PM   #2
dtkarst
Re: Think I should do it?
One more
Old 07-30-2016, 03:20 PM   #3
dtkarst
One more again
Old 07-30-2016, 03:41 PM   #4
Clyde65
Clyde65's Avatar
Hell yes, i would!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-30-2016, 03:57 PM   #5
dtkarst
It's a toss up really between that and this 63 long bed, isn't running right now and needs brakes worked on
Old 07-30-2016, 04:25 PM   #6
DPowers
One foot in front of the other
DPowers's Avatar
Talking Re: Think I should do it?
I would go for both
DPowers is offline   Reply With Quote
Old 07-30-2016, 05:34 PM   #7
Originally Posted by Clyde65 View Post
Hell yes, i would!
If it was a choice, I would do the wrecker, but both would be good.
Old 07-30-2016, 07:49 PM   #8
dtkarst
Well i don't know if I can do both. What separates the two is that the 66 runs and drives custom and bbw with a lot of the work already done
Old 07-30-2016, 08:45 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Does the C30 have leafs in the rear or is it trailing arms with springs? Not a factory dually I'm assuming, according to the non budd wheel up front. It did have the optional reverse lights on it at one time. The reverse switch adapter is still there.
I'd take the 63 over the 66 any day.
Old 07-30-2016, 08:53 PM   #10
dtkarst
It was bought as cab and chassis and made into a wrecker. Has all the tow truck components but not sure if I'll take them or not. Not sure on what do to do on them yet.
Old 07-30-2016, 09:25 PM   #11
aerotruk63
aerotruk63's Avatar
A single rear wheel Cab and Chassis?
Old 07-30-2016, 11:15 PM   #12
dtkarst
I had a 64 c30 that was bought new with can and chassis and the owner put a winch bed on it and pto and it had the 17 in rims on it or maybe 17.5 I don't remember what the options were. But I can't decide between the two, may end up with both.
Old 07-30-2016, 11:33 PM   #13
Willie 66
Do what you'll enjoy most! If starting from the ground up is what you'll find most rewarding, go for the 63. If you're looking for a "work in progress" that you can drive around until you figure out what you want, go for the 66. Ultimately you will make either truck your own, and that's what it's all about!
Willie 66 is offline   Reply With Quote
Old 07-30-2016, 11:40 PM   #14
60chevyjim
60chevyjim's Avatar
I would have to buy both of them before there gone .
60chevyjim is offline   Reply With Quote
Old 07-31-2016, 12:47 AM   #15
padresag
my 65 1t doesn't have budds on it either, anymore
ron
padresag is offline   Reply With Quote
Old 07-31-2016, 01:33 AM   #16
Blue666(2)
I vote for the 66 c 30. Turn it into big block 5th wheel puller or trade the flat bed for a fleetside, lose the duallies for super single with full width tub across the bed floor.
Blue666(2) is offline   Reply With Quote
Old 07-31-2016, 12:53 PM   #17
dtkarst
I'm not real sure which to do..kind of cooled down on both lol
