Old 08-03-2016, 11:51 AM   #1
st3v3o
Brake Line help
I have a 70 C10 short bed. Its kind of a frankenstein truck I lucked out with from South Dakota. I recently put a CPP big brake kit on and now working to replace the lines. Im pretty sure its original lines due to the cracking, clogged and mess its in.
I was tracing the lines and getting distances for steel braided brake lines and came across what I think it some sort of junction/pressure valve. Its located under the radiator, on the inside of the frame. Both lines from the master run to it, along with the rear line and both lines for the front calipers. I've tried to research it, Ive asked other buddies who are more savoy with cars and I'm coming up empty handed. Does anyone know what it is or where I can research it?
st3v3o is offline   Reply With Quote
Old 08-03-2016, 12:27 PM   #2
GWWhite
Re: Brake Line help
Got a photo? May be a proportion value. Did the original have disc/drum combo?
GWWhite is offline   Reply With Quote
Old 08-03-2016, 12:34 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Brake Line help
Sounds like the proportioning valve and line set-up off of a 73-87 truck.
Keith
Convert to disc brakes.
Old 08-03-2016, 02:48 PM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: Brake Line help
yeah, most distribution blocks (drum brakes) and proportioning blocks (Disc/drum) are mounted right below the master cylinder. I bought a replacement line kit from LMC, and it didn't fit for crap, all the flares were a total nightmare to get to seal up, don't waste your time going with a cheap set of pre bent brake lines, spend the extra cash and buy a set of Inline tube CNC bent brake lines, you'll thank your self......
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 08-03-2016, 02:48 PM   #5
st3v3o
I'll get a picture of it this weekend. The original set up was disc up front and drums in the rear.
Old 08-03-2016, 03:11 PM   #6
lolife99
lolife99's Avatar
Re: Brake Line help
The original set up on a 1970 was drum/drum.
Sounds like someone already changed it to disc prior to you owning the truck.
Keith
Old 08-04-2016, 07:19 PM   #7
st3v3o
Re: Brake Line help
Since the new brake kit master came with a proportioning valve, is that forward proportioning valve even necessary?
