Old 08-21-2016, 06:38 PM   #1
Mgicm
Odd acceleration issue
Having an odd issue. Have a 72 stepvan with 250v6. Drives ok around town. Get on highway...wont go above like 45mph. After about 3-4 minutes...it starts to go faster to like 50-55mph. RUns ok speed after that. If i get off highway... turn around and get back onto highway same thing. Slow at like 45mph and then out of nowhere goes to 55+ for no apparent reason. No hills or anything .
Sometimes from a stop it does seem to take some time to get up to speed.
Could this be an issue related to ignition timing etc?
thanks!
Mgicm is offline   Reply With Quote
Old 08-22-2016, 01:23 AM   #2
compsystems
Re: Odd acceleration issue
Sounds like the fuel pump is having a hard time keeping up. Have you checked the pump to make sure you have good flow and that the carb floats are set correctly?
That's where I would start.
compsystems is offline   Reply With Quote
Old 08-22-2016, 07:43 AM   #3
custom10nut
custom10nut's Avatar
Another thing you may look into is the vacuum advance on your distributor. If I has never been changed, the rubber diaphragm inside can dry out and leak. Just something to look at.
custom10nut is offline   Reply With Quote
