Old 04-13-2010, 01:39 AM   #1
BrianV
BrianV's Avatar
Any one have any pics of blazer buckets and console in their truck
I am thinking of buying blazer buckets and consolse for my truck and want to see if anyone else has this in their truck with some pics so i can check it out before i do it
thanks in advance
BrianV is offline   Reply With Quote
Old 04-13-2010, 05:34 AM   #2
JimKshortstep4x4
Re: Any one have any pics of blazer buckets and console in their truck
Here is a picture of the buckets in my son's Burb. The picture is not the best but the buckets are really sharp.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-13-2010, 10:23 AM   #3
HuggerCST
HuggerCST's Avatar
Here's mine.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-13-2010, 08:02 PM   #4
BrianV
BrianV's Avatar
those are both really nice trucks - hugger did you use the vinyl dye on the console and door panels or did you order them that color
thanks alot for the pics - they look as good as i thought they would!!!
Old 04-13-2010, 09:33 PM   #5
HuggerCST
HuggerCST's Avatar
I used SEM vinyl paint on the console & dash, but I bought the door panels, seat covers and visors that color.(sandalwood)
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 09-23-2011, 10:21 PM   #6
jondancer
Do these fit fine with the gas tank still in cab?
jondancer is offline   Reply With Quote
Old 09-23-2011, 11:07 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Yes, they came from the factory that way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-24-2011, 05:46 AM   #8
To end any confusion in this thread,Blazer buckets are no different than truck buckets. They are the same seats. The only thing different is Blazers and Jimmys have tilt forward passenger side mounts and trucks are stationary.
Old 09-24-2011, 07:45 AM   #9
JimKshortstep4x4
jondancer,
The tank does not interfere with the buckets. As mentioned they came from the factory with the tank in the cab.
Here is a pic of my son's 69 GMC and the tank is behind the carpet.
Jim
Old 09-24-2011, 08:32 AM   #10
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
here's the ones in my truck
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 11-15-2011, 11:40 PM   #11
doubleb's69
doubleb's69's Avatar
I know its an old thread but screaminchevypickup are those utility buckets in your truck? The shoulders look really square (or maybe its just the angle of the picture), was just wondering if they fit well with a console?
Also did trucks have the plastic backs on them?
Bud
doubleb's69 is offline   Reply With Quote
Old 11-16-2011, 12:05 AM   #12
No,trucks didn't have the plastic backs. 71/72 bucket seat backs are less tapered than 69/70s.
Old 11-16-2011, 12:18 AM   #13
VA72C10
VA72C10
VA72C10's Avatar
and a stock console won't fit between utility buckets
Old 11-16-2011, 02:53 PM   #14
z10kl
z10kl's Avatar
OK, I been thinking about doing mine with buckets.
1. How do you tell the diff between utility buckets and regular?
2. Do you have to use the truck pass side brackets or will the flip forward one work?
3. If the flip ones work in a truck is it an advantage for any reason?
4. Hugger CST, what color SEM matches Sandlewood?
70 CST
Bunch of old Camaros
z10kl is offline   Reply With Quote
Old 11-16-2011, 03:06 PM   #15
Zoomin
Man of Mini-Talents
Zoomin's Avatar
... And what did you guys use as far as mounting them in a bench seat truck? (seat mounts to cab)
Zoomin is offline   Reply With Quote
Old 11-16-2011, 09:50 PM   #16
screaminchevypickup
Laid Back
No they are regular buckets! They look the same as all the other ones in this thread!!
72 chevy swb
Kyle
Old 11-16-2011, 10:43 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
1) Utility buckets are very squared off and flat seat bottom cushion...no recess in the foam like the regular buckets.
2)You can use any brackets...but you will have to drill holes and then reinforce them. Either 67-72 bucket brackets (truck or blazer (not utility)) will keep the seats just below the rear window. 73-up work but are taller (nice for people with longer legs)
3) I like the blazer brackets for both driver's and passenger seats. I don't need the forward adjustment as I need the seat as far back as it can get...the tilt forward allows access behind the seat either for the gas tank....or if relocated...for storage behind the seats...and for easy access to the jack and hardware on the passenger side
4) Hopefully hugger responds...I know the SEM parchment color is too light so you have to use something else to match...
I found a guy who had a set made very similar to the originals excluding the long brace....used angle iron cut to fit with capture nuts welded on for the seat to bolt into...
You could do something similar or just use large fender washers or similar to reinforce them.....
Old 11-16-2011, 11:10 PM   #18
HuggerCST
HuggerCST's Avatar
I couldn't remember, so I had to check the can and actually it was Plastikote vinyl paint #419 buckskin.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 11-16-2011, 11:44 PM   #19
doubleb's69
Sorry, they just looked more square, like I said maybe its the angle the picture is taken. I'm new to the bucket seat world so give a newbie a break.
Bud
Old 11-17-2011, 08:17 AM   #20
...71/72 bucket seat backs are less tapered than 69/70s.
There's your answer. The other seats in the thread are 69/70.
1. Utility buckets can have the cushions modified,but the original ones are flat surfaced. The back has a tube frame at the edge and all came with steel backs that actually wrap over the side a bit. They are noticeably wider,too.
Here's a pic:
2. You would need the parts from the Blazer floor that accept the seat.
3. I guess if you moved the gas tank it would allow easier access behind the seat. You would only have access from between the seats without. The passenger seat flips right up to the dash/windshield. On the driver side the steering wheel will interfere. If tank is left in the cab,I see no advantage at all.
4. I don't know,ask Hugger CST
Old 11-17-2011, 09:25 AM   #21
JWall
Frequent Flyer
JWall's Avatar
- Justin
1 Owner 1976 SWB
Old 11-19-2011, 11:58 PM   #22
doubleb's69
Love the red JWall!
Bud
Old 09-06-2016, 11:17 AM   #23
72chevynut
72chevynut's Avatar
I know this is an old thread, but while researching original bucket seats I noticed this one mentioned that a console would not fit between utility buckets (with steel back cover). In my 71 K5, it has the original utility buckets (recovered) and a added console. Seats are still mounted original to blazer and console fits nicely between. Seats and console all function properly. Hope this helps any utility seat owners wanting a console.
Michael
72chevynut is offline   Reply With Quote
