Old 10-08-2003, 03:50 AM   #1
RON WOODGEARD
Resident Young Old Dude !
Question Spring to pop hood up ??
I know I read something here a year or so ago, but don't remember what to use.
What year of a truck can we get the spring off of to pop our hood up with? Mine's a real pain, You have to slip something under the lip to pop it up to open it.
Ron
RON WOODGEARD is offline   Reply With Quote
Old 10-08-2003, 04:02 AM   #2
OhioDan
OhioDan's Avatar
Mine would do that until I adjusted it. Now it pops up 'bout 2-3". I loosened up the bolts to the fender and tilted the hood all the way open and then some. Tightened the bolts and tried it. Popped right open. You'll have to do it a couple times to get it right. Just my $.02 .
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 10-08-2003, 07:32 AM   #3
tom hand
CCRider
tom hand's Avatar
Mine was like that. If you lube the hinges it might help. Mine had a bad hinge and once I replaced them, now I have to hold my hand over it to keep it from flying open when I pop the latch
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-08-2003, 08:45 AM   #4
Huck
Huck's Avatar
Ron, try my patented method of hood adjustment and that may do the deal without any modifications. First lube the hinge pivot points real well first with some oil then with some silicon white lube spray. When nice and smoooth, then with the hood open all the way, try adjusting the hinges a bit by loosening the rear two bolts on the hinge to fender adjustment, then push the hood up just a bit beyond the normal open position---just enough to get the hinges to piviot a bit more to the rear. Then tighten the rear bolts. Now slowely bring the hood down. May need to loosen the hood latch plate that mounts to the hood so that the tapered latch centers into the latch mechanism. Once done, the rear of the hood will sit flat with the fenders/cowel. And, when you pull the latch to open, the hood should pop up about 2 " as long as there is no hood to fenders/grill alignment issues. Done this many-many times and it works even with some worn hinges!!! Good luck---Huck
Huck is offline   Reply With Quote
Old 10-08-2003, 10:32 AM   #5
landon4421
Life is Good !
landon4421's Avatar
A buddy of mine Ron, his hood poped up like half way when I puled the hood latch. I was like sweeeeet, mine dose not do that. He gave me the same advice as ( HUCK ) just gave ! I personally have not had a chance to get it done but I will try it out soon here !
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 10-08-2003, 11:08 AM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I had done like Huck said, to mine and my buddy's and both of them pop open 2-3". It sure beats trying to stick something under the lip!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-08-2003, 02:16 PM   #7
RON WOODGEARD
Thumbs up
Ok, Guys I will definetely give it a try...
Thanks,
Ron
Old 10-08-2003, 06:37 PM   #8
crazy longhorn
Fabricate till you "puke"
Mine was a pain in the arse......i welded the hood to the fenders(after i split the fenders). Now the complete clip tilts foward.....no more hassles crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-08-2003, 06:59 PM   #9
67cst
i love summertime
67cst's Avatar
i replaced one of the hinges on my truck a month ago, it doesnt pop worth a darn either, i have to use the G om GMC to lift ... it sucks, im going to go try that fix method from huck and see how it goes
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 10-08-2003, 07:26 PM   #10
Adam12
I hate trannys
Adam12's Avatar
I used to have to pry mine open but then I adjusted it and now it pops up fine, it takes a little time and patence but adjust it and its worth it
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 10-08-2003, 08:51 PM   #11
RON WOODGEARD
I use to tilt every hot rod that I owned, And I'm contemplating this one also.
The only reason this one isn't probably not already done, I lived in a dusty gravel road area for 18 years. I'm not there anymore, Now I can see a Lake off of my deck...So no more dang desert dust on the manifold...
But it will be a ways down the road, Like, maybe a year or so.
So much to do, So little time.
Ron
Old 10-08-2003, 09:11 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I did the huck hood adjustment and the hood has popped up 2-3 inch's ever since.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
