Old 10-23-2016, 11:54 AM   #1
RRC
RRC's Avatar
Carbed LS swap Backfire
I have a stock 5.3 with a Holley carb. I have tested and researched about all I can find. I have talked to MSD and have also tried a Dayton Sensors smart spark with no luck. Everything I have done to this point has made a difference. But i still have a backfire through the exhaust at start up. Good grounds and 12v, new sensors... i have got rid of the misfire and have a good idle. I have tried different timing curves with the laptop. Im finally out of ideas so here i am looking for any help... I'm sure it's something simple..... also have good vacuum.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 10-23-2016, 12:09 PM   #2
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Carbed LS swap Backfire
Does it only happen when cold? If so check the bolts for the exhuast manifolds are headers which ever you are running. They may have a slight gap in them at startup but once warmed up they close up.
Just a thought.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-23-2016, 12:19 PM   #3
RRC
RRC's Avatar
Rocky Lake Kustoms
Russ
Old 10-23-2016, 01:47 PM   #4
davepl
davepl's Avatar
Check your cam sensor connector to make sure it's solid, though I doubt it would actually run otherwise.
Have you changed anything about the ignition tables? If your cranking spark were way off, it'd do that.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-23-2016, 02:16 PM   #5
RRC
RRC's Avatar
I'm going to try a different Cam sensor today.... I have tried different degrees of timing at 0 rpm
Rocky Lake Kustoms
Russ
Old 10-23-2016, 07:29 PM   #6
davepl
davepl's Avatar
I don't know that ECM very well but there might well be cranking spark tables separate from the RPM based table.
